Old 07-13-2004, 11:05 AM   #7936
Neil Rabara's Avatar
Originally posted by gido
How can it be done without the screw hitting the wheel?
Thanks again!
You can change the ball end or shave down the ball cup to make it fit.
Neil Rabara is offline   Reply With Quote
Old 07-13-2004, 11:06 AM   #7937
Kenshin's Avatar
Originally posted by etzkev
Oh, wow, thats wierd!
-Kevin
Nope, not weird at all. It is common actually to drill two new holes for spurs to fit the 3 hole layshaft if you are not using Kimbroughs.
Robinsons, RWs, Xenons, etc. have the same hole patterns that are different from the Kimbroughs.
Kenshin is offline   Reply With Quote
Old 07-13-2004, 11:11 AM   #7938
Originally posted by jag88
Can any of the EVO 'pilots' out there tell me their experiences with the ajustable center oneway ? Good, bad, no change ? Carpet or pavement. It seems that it would be a trick ajustment for fine tuning.
My experience with the adjustable center oneway is to replace it with the locked center shaft.
Old 07-13-2004, 11:12 AM   #7939
Kenshin's Avatar
Originally posted by JDXray
or you could use a x-acto knife to cut the hole.
Use a drill or dremel just like Neil suggested for a cleaner job.
Old 07-13-2004, 11:43 AM   #7940
Precision RC spurs are very nice. The holes line up on that spur.
Old 07-13-2004, 01:29 PM   #7941
jag88's Avatar
Neil, can you elaborate a little. I'm curious as to what you didn't like about it.
I remember a ways back that the HPI Pro 2 offered an ajustable center oneway as an option.
Thanks.
jag88 is offline   Reply With Quote
Old 07-14-2004, 01:28 AM   #7942
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Sands
That setup guide is a blinder man
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 07-14-2004, 07:58 PM   #7943
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Default Set up tips
Does anyone have the address to Josh Cryl's site.....
Kennedy is offline   Reply With Quote
Old 07-14-2004, 08:22 PM   #7944
jag88's Avatar
www.cefx.net/
Old 07-14-2004, 08:55 PM   #7945
etzkev's Avatar
Send a message via AIM to etzkev
Hey all,
I just got a quick question. After installing the Low Ratio Gears, and using the same Spur, I have to go up on the pinion teeth right?
Thanks,
Kevin
etzkev is offline   Reply With Quote
Old 07-14-2004, 09:29 PM   #7946
Oasis's Avatar
Trader Rating: 36 (100%+)
Yea..if you want to smoke your motor.. but really the way to look at it is your ratio is now 1.77(??) so if your running say a 93 spur you would want to run a 23,that would put the final at 7.15..a good starting point for a stock motor,19 wind 21 or 22 and thats with a 93 spur.
Oasis is offline   Reply With Quote
Old 07-14-2004, 09:39 PM   #7947
etzkev's Avatar
Wait a second. That doesn't make sense at all. You are saying a 19 needs to be geared 21 or 22, and a stock needs to be geared around 23. 19's are always geared higher than stock motors!
Anyways, I'm not a newb and I can gear it, but I was just wondering what to expect. So, I am going to have to gear lower?
Oh, and yes, you are correct in that the ratio is 1.77.
Thanks,
Kevin
Old 07-14-2004, 09:56 PM   #7948
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Kevin, you will have to go down on the pinion size switching to the low ratio pulleys. The pulleys lower the final drive ratio, so to get the same one you had, you'd have to go down on the pinion.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-14-2004, 09:57 PM   #7949
etzkev's Avatar
Oh, ok. Thanks for the help Brian. I could have figued it out myself, but I felt kinda lazy. Didn't feel like doin' math or trying differen't pinions!
Thanks,
Kevin
Old 07-15-2004, 02:34 AM   #7950
rice's Avatar
question?
i hav a foc kit whats the problem with this after i check the toe in in the rear its 1 deg. left and 2 deg. right check all the spacers its all der. do i hav to change the arm in the rear or the c hubs?
rice is offline   Reply With Quote
