Xray T1
#7261
RBLove - Cant say for sure right now. I would like to but carpet requires a lot of preparation and there really is no place to practice in So Cal. Never know what the future holds. Thanks for the props dude.
#7262
#7263
HELP ME HODAPP!
Hello Greg,
can you help me on gearing my 19T motor powered XRAY????
And what battery position do you usually run???????
thanxx!
thanxx!
#7264
SalvadoriRacing - What kind of track are you running on. Tight, open, hooked up, loose etc.
#7265
Ouch
Neil,
I am using a JR RS300 With a JR XR3 Reciever and a Novak Dually ESC. When I went into the hobby shop I said "you guys ever have any glitching problems on the track?" Thier reply was oh yeah in turn two the fence runs to close to the track.
Thanks for your interest
#7266
HODAPP,
Here is the track layout, the straight is 60meter.....
http://www.aarcdoabc.com.br/images/pista.gif
I ran today, I tried a final ratio of 5.7, my car (19t motor) is about 1 second slower than modifieds.....
I tried the battery position that josh cyrul uses, but was the first time I run my XRAY, i don't know how the car will react with other batt positions....
#7267
maden run
well ran the new car today and it handled fantastic. Ran a spool so it pushed a little. will try a diff next time otherwise the car runs real smooth. I set up the car with gregs standard set up.
#7268
Re: Spur Gears
Originally posted by psbarger
Hey guys, I'm wondering what aftermarket spur gears work with my FK? I had some Robinson racing ones sitting around but the holes don't line up with the layshaft correctly. Do Kimbrough work? What other brands? I'd like to stay 48 pitch simply so because all my other cars are 48 and I've got tons of pinions....
#7269
Team EAM
PRS or www.precisionracingsystems.com is making Touring car spurs now in sizes up to 132 teeth. Perfect for the Xray so you can get the motor low in the car. Machined and perfectly round and light. Yes I am sponsored by them but I would still run them if I wasnt. Quite a few factory drivers are now running the spurs and pinions as well.
EA
EA
#7270
which trans ratio
I was told the factory fk kit has a ratio of 1.77 and is the best for carpet. He also told me for asphalt I should be running the 2.125 gears any one care to give me some input on this
#7271
Re: which trans ratio
#7273
thanks
so with a 19t what kinda finals should work good with this car I tryed the REEDY (513) quad ran it around 5.7 to 6.3 no punch then tryed the camillion (trinity) up and down the scale still no punch. am I doing something wrong?????????
#7274
From the looks of it, you geared the Reedy quad incorrectly. I don't know much about the Trinity.
#7275
Re: thanks
well, while were at it, what is the difference between a 1.77 trans ratio as opposed to the 2.125 of the FOC? am a bit confused if i need to change to the 1.77. i run on a fairly technical track, asphalt, med grip.
tanx for ur inputs guys.
