Xray T1
#6931
Question
How free is the steering in your T1R? I am in the process of putting in my servo saver and connecting the steering arms. When I do the steering does not seem to be as free as i think it should be. I did smash one of the plastic shims that go onto the servo saver. Could this nake it bind? Help!
#6932
Re: Question
#6933
R/C Tech Elite Member
Quick Questions
Hello,
I had a few questions for xray owners:
1. What size allen driver do I use fo rthe shock bushings? The screw is 2mm, but what size is the shock bushing?
2. Does Xray sell a turnbuckle wrench? I didn't get one with the used kit I bought, might anyone have a part #?
Thanks for the help.
Buddha
Buddha
#6935
Re: Quick Questions
2. The turnbuckle wrench that came with the kit was a flimsy piece of metal. Hardly worth mentioning.
#6936
Re: Quick Questions
Hello,
Buddha
Hello,
Buddha
#6937
ran my xray foc over the weekend, and all i can say is "this car is great"
i was running diff diff and it didnt show a tad of understeer, in fact i was also using the pillow ball suspension, just wanted to give it a try, and it looks cool.
now, i was wondering, what's the difference if i unlock the shaft and make it a mid one-way as opposed to a locked shaft and a one way in front? tanx for the input.
#6938
sorry for the double post.
one more thing, has anyone experienced the loosening of the screw that holds the servo horn? i was cleaning my car yday when i noticed that the screw was really loose.
i've never had this problem with my other cars before.
tanx for infos again.
#6940
Thanks for the info guys, can't wait to drive the car!
If I can't find the hudy turnbtuckle wrench, are there any alternative wrenches that'll fit? I tried my lunsford, but alas, it was too big.
#6941
#6943
Depends what kind of track you're running on. If the track is low grip then it would be best to loosen it a bit.
#6944
How many of you guys are using the Hudy Ulitimate Set-Up System?? What are your thoughts about it? Worth the money?
#6945
I have the setup system. I really like it but the only thing I would change is make the gauges something other than clear. Sometimes its pretty hard to see the marks.
