Xray T1
#6901
Originally posted by rayhuang
If youve got a good Carpet/foam set-up-then go down a few lbs on spring rate- add a thin rear sway bar and go from there.
Ray
Ray
Blake
#6902
Re: rear belt
Originally posted by 1shnot
hi guys.....
i've changed to 1.77 pully set and now my rear belt is really loose...............
I've changed the rear bulk to make it tigher but still way too loose
what's up? please help!!!!!!!!!!
hi guys.....
#6906
Originally posted by NVisible
whats the difference between a T1R and say... an EVO2 other than the chassis?
Composite shock towers vs. CF
Composite battery straps vs. Alu + CF
Composite servo mount vs. Alu
I'm probably missing a few others...
The Evo2 FOC (Freedom of choice) had both C-hub and pivot ball suspension parts.
#6908
yes the T1R comes with C-Hubs, great car. I might be getting rid of mine
Here is where i got mine: http://www.thercshack.com/index.asp?...PROD&ProdID=79
Really cheap, retail on T1R is around 230-235 i believe and getting it for 185 is a great deal.
#6915
If someone is looking for a t1R I have one brand new in the box.....180.00 shipped anywhere in the USA
Eric
Eric
