Like Tree3Likes
Xray T1
Old 11-24-2003, 04:56 PM
  #5221
Regional Moderator
It is true, also hudy will be distrubted by Horizon. They have promised to have a complete inventory in stock within the next week or so. Only hope they can do it.
volav is offline
Old 11-24-2003, 05:53 PM
  #5222
Does anyone know where I can get the 1.77 pullies I have been unable to get them my hobbieshop says he cant get the till next month or next year
skyking is offline
Old 11-24-2003, 06:12 PM
  #5223
try www.ashfordhobby.com
DOTMAN is offline
  #5224
Scrad's Avatar
Trader Rating: 16 (100%+)
try ashfordhobby.com they usually have most everything in stock Or stormerhobbies.com
opps, we posted at the same time.
Scrad is offline
Old 11-24-2003, 06:23 PM
  #5225
ok thanks guys ill try that Stormer is out of them
skyking is offline
Old 11-24-2003, 06:24 PM
  #5226
rcmike's Avatar
Trader Rating: 40 (100%+)
Default first elec car
Hi, Would a evo2 freedom of choice car be a good car to buy for my first electric car?? I run 1/8 scale on and off-road,also touring car, so im not a newbie to racing,just a newbie to electric A LHS opened up a indoor carpet track and was wanting some more stick time{its gettin cold in texas now} Thanks
rcmike is offline
Old 11-24-2003, 06:27 PM
  #5227
JusBox's Avatar
Default Re: first elec car
Man I wish I had a local hobby shop that was worth a d*mn... anyway, it's a great kit but can be complicated for a beginner due to all the tuning choices. However, if you stick to the stock setup and make one change at a time you can definately learn the car, go for it!
JusBox is offline
Old 11-24-2003, 06:43 PM
  #5228
Hey RcMike, I raced my Evo2 at Mike's new carpet track last saturday. It was a blast! Xray was #2 and #4 in the Mod-A. I love mine! It's a versatile car with all the setup changes you can make to it. I'm pretty sure Mike's carries Xray parts.
Surge is offline
Old 11-24-2003, 08:30 PM
  #5229
JusBox's Avatar
How are you guys building your xray shocks? I've been at it for hours now and I'm getting frustrated! I just can't get them the way i want.
JusBox is offline
Old 11-24-2003, 09:05 PM
  #5230
sands's Avatar
If its the oil....
1. Fill them all the way
2. Compress the shaft about 1/2 - 3/4 of the way.
3. Put the little bladder on and squeeze out air bubles. Hold the shock at a 45* angle to do this. Put the lower side of the bladder in first then roll it on towards the upper end (with the shock tilted). This will squeeze out any air that is trapped.
4. Extend the shaft all the way and put the cap on. This will suck the bladder down and it won't pop off.
I also found some translucent bladders that you can see the air bubles under. i think they are yoks or something. Not really sure.
I get no air and the action is very smooth with only a little shaft extension when it is compressed fully.
sands is offline
Old 11-24-2003, 09:56 PM
  #5231
JusBox's Avatar
Originally posted by sands
If its the oil....
Well after half a bottle of losi 40, i think i finally got all four to be somewhat equal. Thanks for the tips. (here's what i did differently... i put a four mm and a 1 mm spacer clip on the shaft to make sure each shock was pushed in the same distance. After that and following your advice they were all pretty good... i had to bleed a little out of one of the shocks to equalize the rebounds) I've got oil everywhere so good enough for now!
JusBox is offline
Old 11-24-2003, 09:58 PM
  #5232
Trader Rating: 56 (100%+)
Default Xray SSG Chassis
Booyah! Just got my Xray back from Xtreme Racing. He was using it to prototype the chassis for the car...works on the T1, EVO2 and T1R
Looks sweet, the upper chassis is a bit stiffer then the factory stiffy, new chassis is stiffer then the factory Evo2(as stiff as the T1 chassis)
Check out Xtreme Racing
I dont work for them, but tell em Eric sent ya and he will hook you up!
I can't wait till I have the chance to throw this piece on carpet!
dynamic_e is offline
Old 11-25-2003, 04:59 PM
  #5233
Neil Rabara's Avatar
Default Re: Xray SSG Chassis
That is pretty! Other colors?
Neil Rabara is offline
Old 11-25-2003, 06:01 PM
  #5234
Ou stiffer than stock chassis, is that where it is ?
ZER01 is offline
Old 11-26-2003, 06:46 AM
  #5235
redsand's Avatar
Has anyone tried Serpent shock o-ring in the xray shock ?
redsand is offline
