Like Tree3Likes
Xray T1
Old 10-05-2003, 03:17 PM
  #4876
psmart2's Avatar
I would like to have one.
psmart2 is offline
Old 10-05-2003, 04:23 PM
  #4877
Neil Rabara's Avatar
Default Re: Xray Car Stand
Originally posted by siebenelch
Do you like it?
Michael
Where did you get it?
Neil Rabara is offline
Old 10-05-2003, 10:08 PM
  #4878
siebenelch- That car stand is sweet. Where did you get it? btw, do you think you could of put a bigger capacitor on your speedo .
I went to a race down in Salem, OR this weekend. It was pretty good, my car was handling great. Aside from the times when the c-hubs would break. I completly broke 2 and started to break 2 more but I fixed those with CA glue. Has anyone else had this problem before? But one of the weirdest things was that I didn't ever chunk a foam tire. Not once, not even a slit in a tire. The most was the tire just started to come off the rim in a couple places. Another guy I know who was running a t1r was breaking c-hubs a lot too.
I think it might of been the bolted in pvc pipes with 35 pound steel plates in the corners . Those sure were pretty hard on your car. Because when I drove the car at my home track where we use velcro plates with pegs that go into the pvc pipes to hold them in place I've never seen a x-ray c-hub break. And the first time out with the x-ray I have to was hitting more pipes than did in salem. Oh well, I guess I'll just get some aluminum ones, those should last a while.
racerdx6 is offline
Old 10-05-2003, 10:49 PM
  #4879
If you go with the alum ones, then you start breaking the arms. Your best bet........don't hit the pipes. A similar thing happened to me with PVC pipes.
Old 10-06-2003, 04:45 AM
  #4880
Itīs made by VITEC SYMBIOSIS.
Greetings
Michael, VITEC SYMBIOSIS
siebenelch is offline
Old 10-06-2003, 05:47 AM
  #4881
Originally posted by Trinityracinnut
Yes
run 0 degrees squat front and rear
-1 camber
2 degrees toe rear
1 degree toe out front
254mm wheelbase
2 hole open front
3 hole rear
30 wt oil
stock positions on towers
ride height 5 mm
9.6 degrees caster
45 degree front bar, medium setting
2mm rear bar
TO 27 premount tires
stratus 2.0 body
stiff upper deck
Trintyracinnut
What springs do you use for this rubber carpet set-up ?
Ralf is offline
Old 10-06-2003, 06:45 AM
  #4882
Scrad's Avatar
Trader Rating: 16 (100%+)
Does anyone make a 64 pitch spur bigger than 128. I have to run such a small pinion with the low ratio pullies, like 22 and my motor touches the belt even with the belt tighter.
Also with the motor out, does your drivetran spin better with the low ratio pullies or the stock. My experience seems like the low ratio pullies don't spin for quite as long compared to the stock setup. [/B][/QUOTE]
Scrad is offline
Old 10-06-2003, 07:02 AM
  #4883
mike_Webb's Avatar
Scrad-
I have never seen anything bigger then 128
mike_Webb is offline
Old 10-06-2003, 09:57 AM
  #4884
Greetings
Is there an English version of the website?
Old 10-06-2003, 01:57 PM
  #4885
Tommy Bergfeldt's Avatar
what do you guys think of the Solid front diff? Coz i'm thinking of buying one and use it on small twisty tracks where i need loads of acceleration and great breaking ability.
Tommy Bergfeldt is offline
Old 10-06-2003, 02:11 PM
  #4886
What type of track is it, and what Xray car do you have?
Old 10-06-2003, 03:20 PM
  #4887
StephenSobottka's Avatar
Ralf- I use the Xray Whites
StephenSobottka is offline
Old 10-06-2003, 08:32 PM
  #4888
XRaycer's Avatar
racerdx6- I had the same problem with the C hubs I made a kydex bumper that I layed on top of the foam bumper (as wide as the body would allow) now I only use it at certain tracks. And I replaced the foam bumper and it seemed better or maybe I just dont hit the PVC as hard anymore.
RCInfinity- where do you get your 5 minutes.
XRaycer is offline
Old 10-07-2003, 07:16 AM
  #4889
sands's Avatar
Default xray rollouts
I put together some rollout charts for the xray. With 1.77 and 2.0 tranny ratios.
Sands
File Type: pdf
sands is offline
Old 10-07-2003, 07:17 AM
  #4890
sands's Avatar
and the 2.0 rollout
File Type: pdf
sands is offline
