Xray T1
#3061
T1R vs. evo2
Okay-the T1R adjusts the rear toe in from the back of the arm-which is great. The evo2 from the front of the arms!!! Not bad as long as you pull the motor out. So my question is this!!! Will the "feel" of 2 degrees of toe in be the same if you switch from the T1r set-up from the evo2???
if anybody has the T1R already-could you please look in the manual and post the part numbers needed to make the conversion. I just want to do it for convenience!!!
Ray
Ray
#3063
I had taken apart my T1 apart and cleaned everything, car is smooth.
My Evo 2 is just sitting on the shelf for now. I'm only using the Evo 2 for carpet, and the T1 for asfault.
#3064
Originally posted by RCCadet
You finally bumped into Tony.....he is a cool act.
#3066
Oh sorry, I thought Atomic ran at your track. I'll talk to Ralph. Heard Shreven might make it out. How about you?
#3068
Hey,
Do you think Xray will produce the C-Hub suspension arms in aluminium?
I got KO on the weekend, my rear lower arm got snapped and my rear shock exploded... It was a good hit ! All my oil was on his windscreen.
And the bad thing was it was another Xray that hit me.. At least i got his number plate!! hahaha
#3069
Re: T1R vs. evo2
After looking at the pics of the T1r it looks like the rear toe is adjusted the same as the Evo 2? Am I missing something?
#3072
Re: Re: T1R vs. evo2
The evo2 the rear of the arm is fixed by the aluminum tube. But on the T1r-the rear of the arm is not fixed and it is from there you add or subtract the rear toe-in. I'll post pics so you can see what I mean!!!
Here is the T1R first:
#3074
Re: Re: Re: T1R vs. evo2
JBrake-how was Toledo??
I see how you could change toe by using the rear mount, but I don't see how that wouldn't shorten the rear track at the same time. If you put the 3mm clip in the front "permanently" then you could adjust from 0* to 3* of toe in, but the rear track would be (+/-)6mm shorter. I think that is how you are suggesting it would work?
#3075
ya, i would guess if you adjusted the toe-in using the front pin mount that would make for a shorter track in rear as opposed to adjusting the toe-in with the rear pin mount which would make the rear track slightly wider.
i agree with ray though i would rather change to the adjustable rear mount instead for convenience, although i am still running the pillowball so no need for me haha.
