Novak Kinetic
#631
Company Representative
Here is the info on "bug fixes" that I mentioned above:
Firmware Update Download
NovaLink Update Download
Our information clearly states that the NovaLink is compatible (only) with Windows® XP™ and Vista™ computer-operating platforms. We are investigating other platforms, but at this time we are unable to help, or troubleshoot, any other systems.
#632
When I bought this, I know I could have selected other brands with software further developed, but I've always liked Novak.
The minor issues I've had, and the speed in which your company acted to solve them, makes me believe in you more.
Now, I suppose there is no need to download the new Novalink full 1.3 if the older link has been updated with the new firmware, right?
#634
Just got my novalink yesterday and had a very frustrating night trying to install it so thought I would share my findings in case anyone else is going through the same problem. Most of this is in the last few pages but thought it might be helpful to have it in one post.
When trying to update the firmware the instructions aren't all that clear so after going through the last few pages and piecing together the responses I got the following. When you are prompted to turn on the controller it actually means connect the controller to the Novalink. You don't need to have a battery connected and the switch doesn't need to be turned on. If it doesn't start updating in the first few seconds unplug the controller from the Novalink and then try again. Took me 10 tries to get it to connect and update the firmware the first time. On the second update attempt just to be sure it had worked took 4 tries to connect.
Once I had the firmware updated tried to recalibrate my radio and all appeared to work okay button wise except the solid red for neutral. It just kept flashing a variety of light combinations. Finally realised after a few attempts that these looked like the light combinations for button programming. Then tried turning on without calibrating and red light came on solid as though the switch was depressed though I wasn't holding it down. Suspected a faulty switch so removed the switch and bridged the positive and negative switch pins at the controller and plugged the battery in. This time it started up normally and I had throttle response. So seems after 1 practice day of use the switch has failed just have to try to find a replacement switch now to confirm that this is all that is wrong.
#636
so ive got a novak kinetic and a ballistic 550 4.5 motor, and there both brand new. when you give it hard throttle, it will turn inself off, but the radio and servo still works. it will turn its self on right away afterward too.
sometimes it wont turn back on and if you give the vehicle a little push it will turn back on again.
i talked to the novak tech support guy and he has never herd of this so have any of you guys herd of this, or have any idea on what it could be. ive tryed different batterys, different servo and different radio and it still does the same thing.
im not to happy about this because i spent close to 400 bucks for this system. any help would be great
#637
#638
But that's per cell, not for the whole pack, I believe that's how it works anyways, I have mine set at 6.4 (3.2/cell). I know I felt my car slow way down last week during a long practice run so I figured I hit my cutoff and threw the battery on the charger to find out my 2S pack was at a low 5.4v. I plugged into the NovaLink and realized I had forgotten to set the cutoff since the new firmware or something and it was still at the factory value of 3.x.
#639
#640
I installed both of the 1.3 versions and it did not work. I removed them and dropped back to 1.1 and will stay there until things get figured out!
#641
I wonder if it wasn't working at all then. Maybe that's why when I plugged mine in the value was so high. I will have to play with it with the new firmware and see if it actually works. Easiest way to test it is with an old NiMH pack, the lights will let you know if it goes to lipo cutoff.
Just set it at something like 8.2 and run it for a few minutes and it should drop to that pretty quick and limit you then, just so you don't run a whole pack to find out.
#642
so how do i get 1.3 IN the speedo
yep me too. we should soon have an answer
#643
I got the 1.3 update to apply. I left the ESC plugged in, started NovaLink, unplugged the ESC and plugged it back in, got the you don't have 1.3 error, clicked ok, started the firmware update, unplugged the ESC and plugged it back in right away when it asked. Try a combination of that if it doesn't work, I had to restart windows after the update. This isn't easy to do, but it will work if you keep trying.
If it's the middle of the night and you can't sleep because your wife is about to have a baby, you will get it to work.
#644
With the new 1.3 software, it'll only let you update the firmware if you have 1.1/1.0.
I noticed I had to widen my dead band with 1.3, I had it at 2 previously, and it wouldn't recognize neutral correctly, it kept trying to start the motor, and what's even more strange is one of my speedos is happy at 3, but with the other I needed to go up to 3.5 for it to always actually return to neutral when my radio did. But for anyone using a bigger dead band than that you should be fine.
I think the strangest thing to me and my biggest gripe is how you lose all of your settings every time you go to calibrate your radio. I never understood why calibrating high/low/neutral should reset drag brake, timing, dead band, etc.
#645
Looks like I'll be taking advantage of Novaks warranty policy. LOTS of smoke, a dead esc and link......Not good.
No idea what happened, but whatever it was probably did not go as designed.
