Novak Kinetic
#301
Taken off the Kinetic 1s press release......
"Moreover, Novak added a timing indicator LED, which will illuminate white whenever timing is activated. This feature is approved for ROAR Sportsman Class Racing, and will help aid club racing events that run timing and non-timing events."
Sounds like they have a designated ROAR approved profile setting for no-timing advance for the Sportsman class. All the other settings should allow for tuning for either Stock or Modified classes where timing advance is allowed.
#302
I read that too. But if you read NovakTwo's answer to my question #5 he says the opposite.
http://www.rctech.net/forum/7649262-post293.html
Either way I'm sure it will be good. But I'll be staying with what I have.
#303
Company Representative
Both Kinetics offer a Sportsman (ROAR) mode setting with no timing. When the timing LED is OFF, all timing is OFF.
#304
#305
When I read "Stock Spec", I thought you meant a separate, (cheaper, higher on-resistance) Kinetic esc optimized for spec racing---compatible with higher wind motors .
#307
(HP/SC) Novak's Dynamic Timing Advance™ increases the motor's RPM dynamically through the throttle band for higher speeds—eight on-board adjustments from 15° to 42°.
#308
On the Kinetics, the on-board timing adjustments go from mild (-0-) to wild (55). The Havoc Pro SC has on-board (only) timing adjustments from zero (Sportsman) to:
Next week I plan to have a listing of those additional options that you can only access using the NovaLink. Many racers will not need the PC programming to use the Kinetics successfully.
Ah, very nice! I may just have to pre-order myself a 1S.
End of July still looking good?
#309
#311
We began shipping the Kinetic 2S controllers and the Kinetic/Ballistic Systems (10.5, 13.5, and 17.5) to our distributors yesterday.
#312
That's great. Are you planning on offering an upgrade program for GTB owners? I noticed that your trade up program doesn't currently have this option.... I was hoping it was because it wasn't available yet.
#313
#315
can you post what Dynamic Timing Advance does and what actual settings we'll get for timing and the ranges of values? From the website i can't see any differences to the competition and i really, really want some
