XRAY T3
Old 10-22-2009, 09:18 AM
  #361
M-Technic's Avatar
Trader Rating: 15 (100%+)
My apologies if this was answered in this thread already, but:
Are the 008/009 suspension pieces carrying over to the T3? So if you have arms/c-hubs/knuckles from the T2 it would prevent you from having to buy a whole new group of spares?
M-Technic is offline
Old 10-22-2009, 09:34 AM
  #362
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
They are all the same. You can go to the teamxray site and download the parts list as well. The rear has the optional 2 hole 303165/303166 arms though. They are not "new", just an option T2 part.
ChristopherKee is offline
Old 10-22-2009, 09:37 AM
  #363
Regional Moderator
CarbonJoe's Avatar
Parts cross reference list:
http://www.teamxray.com/teamxray/sho...p?file_id=6147
CarbonJoe is offline
Old 10-22-2009, 09:41 AM
  #364
M-Technic's Avatar
Thanks!
Old 10-22-2009, 10:16 AM
  #365
Big Features's Avatar
Originally Posted by syndr0me
They're doing very well in the US. However, there's that small issue of: Worlds, Reedy, TCM, ETS, DHI, European Champs...
You mentioned Reedy, Xrays have always done well there.
I think a lot has to do with the driver. Most of those guys in Europe drive a different type of track. Car popularity comes and goes.
But Xray T-what ever will always be in the hunt and hard to beat in quality and performance.
Big Features is offline
Old 10-22-2009, 10:17 AM
  #366
There is something different about either the c-hub or steering block.
The slideshow for the T3 shows how there is a greater steering throw as compared to the T2 008-009. It says something about one or the other being redesigned.
That might mean the new part will fit the older platform though.. much like the new arms fit the older T2 platforms.
Dondor is offline
Old 10-22-2009, 10:18 AM
  #367
M-Technic's Avatar
It could be a change in the steering rack.
Old 10-22-2009, 11:35 AM
  #368
No the slideshow shows the 009 steering block impacting the C-hub and the angle of throw for the axle. Then shows the T3 doing the same thing with an increased throw. You cannot get that from steering rack changes. It is a set maximum throw based upon where your kingpin is related to the point the arm impacts the C-hub.
Just looked it up on the slideshow. 18th slide. "The new modified steering blocks allow..."
Dondor is offline
Old 10-22-2009, 11:38 AM
  #369
M-Technic's Avatar
Yep, I just saw that as well.
Old 10-22-2009, 11:44 AM
  #370
Gone Racin's Avatar
Steering blocks are the same. Part #302252 for the T2 and T3 platform.
Gone Racin is offline
Old 10-22-2009, 11:47 AM
  #371
That will probably mean it will be a running change and old parts will still be out there with the same part number.
It looks like on the block where the arm part connects to the upper mass (where the kingpins mount) has an undercut.
Dondor is offline
Old 10-22-2009, 01:40 PM
  #372
Azman Azam's Avatar
I had a long day going thru the cross reference list of all the parts ('009 vs T3) & couldnt see what the difference with the steering block part number.
Part number is still the same (302252) COMPOSITE STEERING BLOCK - MEDIUM - RUBBER-SPEC - V2
but the description changed with the "V2" at the end in the T3 manual compared to the T2009.
Please correct me if i am wrong.
Azman Azam is offline
Old 10-22-2009, 02:25 PM
  #373
Johnny Wishbone's Avatar
I thought the steering increase was because of the re-location of the bellcrank system.?
Johnny Wishbone is offline
Old 10-22-2009, 04:23 PM
  #374
Trader Rating: 14 (100%+)
Nexus 499 pre order . FYI
rushrush1 is offline
Old 10-22-2009, 04:36 PM
  #375
Regional Moderator
CarbonJoe's Avatar
The same thing happened when they revised the C-hubs for the ECS driveshafts. The part numbers stayed the same, but they are now "V2". So, to maintain the steering throw with the wider opening in the C-hubs, they had to take a little material away where the steering knuckle would hit the C-hub at full lock. Given that the C-hubs and front arms are the same, the only way to get more steering travel is to back cut the knuckle. Once the knuckle contacts the C-hub, no matter what the steering rack geometry is, you aren't getting more steering throw because the C-hub acts as a positive stop for the knuckle.
