Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#346
10 SL without topdeck and with saddle pack lipo
I mean I want to use saddlepacks. 2 1S cells glued together with doublesided and then taped on the chassisplate or two 1S cells seperately mounted on the chassis.
Either way: there is no support for the centreshock on the chassis. How to do that?
When the 2 1S cells are glued together the centreshock has to be longer because it has to reach over the 2 1S cells and there has to be a strut in front of the saddlepack to support the centreshock on the chassisplate.
When the 2 1S cells are seperate the length of the shock might be good but again there is no strut for the shock on the chassis. In this configuration the centreshock is kind of in between the two 1S Lipo cells.
So how to go about as to this problom?
#347
RC Devil pancar
Is the weight of this car a problem?
It weighs 1.285 grams raceready.
The rules state that a cars minimum weight is 1.200 grams. So the car is 85 grams too heavy.
There are already clubs that have 1.100 grams as minimum weight. Than that car would be 185 grams too heavy.
The car is awesome. But can all of that add up against the extra weight it carries. IMHO I think not.
#348
Extensionkit for Serpent S100
#349
120A v2.1
it is a very good esc.
-updatable
-good ballanced power delivery "smooth"
-easy to program all parameters with the small LCD box that fits in your pocket. With the LCD setup box it is a breeze to change a setting on the fly.
-price friendly
-easy to figure out what each parameter does and it is vissible on the track or temperature wise.
-good communications with a hobbywing representative here on rc tech.
In fact in the pro10 class at my club many have switched to Hobbywing just for the above mentioned reason. See statement above
It is the same for the 1/12 class that is being driven in the winter overehere. There are many that use the hobbywing 1s 120A esc with build in voltage booster.
For outdoor applications I would advice always to buy the biggest esc you can get for you money. The 120A v2.1 instead of the 60A v2.1 for instance. For me the extra capacity translates in less heat in 10.5t applications and better fett life and power delivery.. The cooler the electronics the better and it is always possible to stick a mod motor in if you feel like going even faster. The price diverence is not that shocking.
-updatable
-price friendly
Is this speedo kinda like the SpeedPassion, but B-label?
Where best to buy it? HongKong?
#350
How to mount the centre shock when not using the topdeck of the Corally 10 SL Link?
Here is a picture from the car of mathijs (pro10holland) with his solution for fitting a 2s saddlepack. (hope you don't mind mathijs )
#351
I, and other drivers that run in the nationals run with 1230 grams in our club pro10 class. There is no difference in speed or handling in the corners between the 1100 gram cars or 1200 gram cars. At least i really don't see it when driving my car.
#352
Hobbywing is the manufacturer of the speedpassion esc so i gues the 120A v2.1 is more of an A label then speedpassion is.
The Hobbywing 120A v2.1 is a good esc. You can buy it with confidence.... i use the 120A v2.1 myself.
This is my car with the hobbywing 120A v2.1 installed
#353
Solution
2 times 1s lipo is difficult. You can put in a 2s saddlepack but not sure if two 1s 1/12 lipo's will fit without drilling a hole. I do see another screw hole a little further forwards in the middle of the chassis. So maybe that is something you could use to fix a shock post..
So they have to be custom made?
That is as to the shock post and the length of the shock.
Not something I could do myself. So there's another problem.
Lots of pancars nowadays use 2S stick LiPo in the middle of the car, lengthwise.
There is some discussion now and again about what is the best way to go. 2S stickpack or 2x1S saddlepack right in front of the rear axle. What would be your opinion on this?
Some say pancars handle better with saddlepacks, especially with cornerentry. Because with pancars it's all about weight on the rear axle some say. I doubt if that is true. A lot of pancar manufacturers would have made the wrong decision then in constructing there car.
Read a review on the XRay X10 Link the other day. These two people stated the exact opposite. 2S Stickpack Lipo would be much better, so they stated. The car would handle much better in left-right-sweepers, better weightbalance.
Another thing that is said is, that indoor on carpet 2S stickpack is better and outdoor on asphalt/tarmac with low to medium grip saddlepack right in front of the rear axle would be better.
I am kind of lost here. Any suggestions from anyone......?
#354
indeed it is custom made part for his car but you can put a standoff there with a ballstud ontop to fix the shock or something DIY. It is a pancar so DIY is not so difficult. You can go into a hardware or electric store and buy something to put there with a 3mm thread to screw it on your chassis. Not so difficult i think. Same with extending your shock shaft.
http://parts.digikey.com/1/parts/442...5mm-24398.html
#355
stickpack is easier to get then saddlepacks. There are more stickpacks as well so plenty of choice. Some say that stickpacks are better as you have less cells then the saddlepacks.
For indoor applications i would go for stickpack as weight on the back is not important and weight on the centerline is important for less side to side weight transfer in corners. There is traction enough on carpet.
For outdoor I have seen all kinds of configurations win. Stickpack down the middle, sticpack on one side and electronics on the other, saddlepacks at the back or a stickpack at the back (croswise). Not sure what is better outdoors. Theory would suggest that more weight at the back would give you more traction when accelerating out of the turn. The theory also says you will get more steering entering the turn and in the middle of the turn as weight will go forwards.
I drove my 200mm BMI DB10RR once on an outdoor track with 2s saddlepacks side by side in the middle and the electronics at the back (the BMI way). After i got my setup right i had no problems hanging with the wide cars and i was using a sophia body.
I think there is not a one best solutions and you always end up with a compromise in outdoor applications. It is still up to the driver how he set up his car and his driving style.
The manufacturers are designing there new 200mm cars based on more or less carpet setup for world gt. With stickpacks you also don't need a wide chassis and can make it narrower.
#359
#360
First get some servo posts . I bought aftermarket aluminium posts from Liquid rc.
Buy the original large Kimbrough servo saver as well. The one in the picture is not the original kimbrough saver that is included in the kit. Just rebuild it like the manual and it should be ok.
Remove the nerfbars. Get some carbon or frp ride hight shims for the front if it isn't included. It is very handy.
Some might disagree but i would get a TRF shock or something similar. It works better then the old asso shock imo. Put some teflon tape on the topplate where the friction disks are. That is pretty much it. You can drive it the way it is.
If you want some more setup possibilities you can make a rc10l2.5 later. When the axle breaks you can look for the IRS axle and hubs. They last a long time.
