Ofna JL-10 E
#796
Waiting on mine should be here thurs. lhs ordered it . paid like 109 for it . will be raced in a spec class running the venom 21d brushed motor and hpi vintage tires . and has to be 8.1 fdr. i think this car will be good for this class . with the right setup and some driving skills i think it will be fine ..
#798
Here is a link. This may be the part I can't recall for sure:
http://www.abchobbyusa.com/frontonewayunit.aspx
#799
Sorry I do not. You may want to contact them.
Thanks for the quick response, I found the PN at TQRacing, http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1, The PN is 24177 for those interested. I raced the JL10 on RCGT last Saturday and it's a great car for the price, the only issue I had was the front diff screw broke, that's why I'm going to try the spool next time.
Do you recommend the Spool over the diff for parking lot racing?
Regards, jb
#800
Front Caster Adjustment
Being new to Touring cars, but not to onroad, how is the front end caster adjusted on the Ofna JL-10e? I raced 1/12 onrood for many years (long ago) and caster was an inportant way to make the car react differently as far as "turning in the corner and off the corner". Maybe I'm wrong, but the JL-10e seems to have too much caster to make it attack the corner off power. Some advice would gladly help. THX in advance-Russ
#801
So far I have not found one that fits, thought the LD3/CD3 swaybar would work but the holes in the blocks are spaced too wide.
#802
Anyone experiencing center driveshaft issues? Mainly lots of flex at higher rpm? I noticed mine doing that after plugging in a 3s and giving half throttle in air and seems it does it with 2s full throttle too (never did full throttle checks before). The car only has a couple runs in it, no mild wrecks and everything else is silk smooth. Just wondering if the high rpm flex would be problematic under load as well or if it's a normal thing. This is my first shaft tc so excuse the ignorance. Runs perfect on 2s, sharp, no noises, very stable, and I wanted to try a 3s for kicks.
#803
Hi guys, those of you with more experience with the car. Have you done a mod or fitted a different diff screw??? Love how the car handles but keep breaking diff screws, and only running a 20t.
Thanks.
Thanks.
#804
Abc hobby has a aftermarket screw or a front spool..I have broke a couple...think the dog bones bind during acceleration Out of corner..
I've ordered cvds will post afterwards
If it corrects problem
