Ofna JL-10 E
#481
Well if I were you try getting a medium spring upfront and a soft one in the rear. to hard of a spring will make the car carve way to hard. um well i use 50wt in the front and 40wt in the rear, but i'd start with 50 wt up front and then adjust droop first before changing the springs. sometimes droop is the the only adjustment you need at the track, i've learned that from the best. But change springs if you feel that when your car turns it tends to fall over or be too soft up front when you turn then you will have to go to a harder spring, but other than that just try a thicker oil up front and change the droop and you should be fine, also what tires are you using and with what body?
#482
Setup for a Noobie
I guys
If been into RC for 3 years now, mostly off road bashing since I never lived near a track. Recently I started looking into on road racing, and over the weekend I bit the bullet. I'm planning to race in the open stock class (Touring Car).
Currently I'm running a silver can with a Novak GTX, but that doesn't matter if you don't now how to setup the car. The track that I'll be running on is clean tarmac.
At this moment i put 50wt shock oil all round and my ride height is about 6-7mm. The rest of the car is stock standard, I be changing my gearing soon as well.
Can someone please help me with the setup of the car?
#483
I guys
#484
Hi,
I just got the car so I'm still siting with the stock x-patterns that comes with the kit. The body is the body that you see in the JL10-E manual, (it's the body that comes with the car here in South Africa (distributed under Hong Nor)).
The track has good traction and has a nice long straight with a banked curve so it's quite high speed. The gears that was recommended to me is 36 pinion and 78 spur with the silvercan.
#485
Hi,
#487
Thanks for all the help with the setup. I'm going to the track on friday to see how it runs, very excited since it will be my first time running a tc on a track so hopefully all goes well. What shock spacers will you recommend? The track is definately one of the best i've seen.
#488
#489
Thinking about getting a 10e - seems like a great and affordable way to get into touring cars.
My only concern is that a lot of the typical places to buy parts don't seem to stock them (amain, tower, etc). Where do you guys get parts?
#494
Just ordered up a JL-10 E.....subscribed! Now I need to read this whole thread to get a heads up on the quirks.
#495
JL-10e Stock Spur size
Guys, what's the stock spur size that comes with the JL-10e. I want to run at TQ, WCRCR, CalRaceway here locally and wanted to get an assortment of pinions/spurs to start with. I appreciate the help.
