KO PROPO EX-10 Helios q's
#1892
Originally Posted by JasonC
in the lower right hand corer of the vfs manager screen is a com selection drop down menu.. just keep changing it until it works.
If it helps, I took the recommendation of theisgroup and got the Serial-to-USB adapter for my laptop for the ICS adapter.
#1893
Click on "Start"-> "Control Panel" -> "Performance & Maintenance" -> "System" -> "Hardware" tab -> "Device Manager" -> "Ports (COM & LPT)"
There you should find the exact allocation for your USB->Serial adapter. Once that is found, make sure that you have the COMM port set correctly on your software. Make sure that you have all wiring connected correctly.
Now some USB->Serial adapter don't work properly with our software. This is stated in the instructions. I can tell you that I have had success with the Belkin adapter.
#1894
Hey KO Staff, took look at it again this morning. I did match up the Com Port number in the Device Manager to the settings in the software. Still no go. I even re-assigned com numbers. I did pick up the Belkin adapter. Huh, might have to try it on another computer. Not giving up yet. I don't supposed OS's might have something to do with it?
#1895
Our software should work with Window 98+. You might want to check the OS that the adapter can work with.
Maybe others that are using adapter can post which brand they are using along with the OS being used?
#1896
Thanks for all the help guys Will try the wife's laptop when I get home from work. And let you know the results.
#1899
Mars R
Robert from KO Usa,
I am looking for a Mars R dropdown unit. Do you have one in stock? Do you know a place that has one? How long to get one in stock?
Does anyone else have a Mars R dropdown unit in great shape. Please let me know. I am only looking for the dropdown.
Thanks Everyone.
Steve
Thanks Everyone.
Steve
#1900
Steve-
We have no more wheel extensions for the Mars series radios, sorry. These have been discontinued by Japan.
You may have luck on ebay trying to locate one.
-Robert
-Robert
#1902
#1904
Originally Posted by subaru73
hello i am wanting to know if a futaba digital servo will work with this radio? i am using the spektrup pro system,and if i can use it what setting do i have to use.let me know.
#1905
Hi Ko staff!!!
Got a question on ST BALANCE,mine when i adjust for left side it will appear a cursor then we tune it at the steering trim.The problem is i cannot do it for the right side,the cursor for the right also did not appear.Please help me !!!!
