KO PROPO EX-10 Helios q's
#1877
ouc an use the ko rx, but you will need the ko rx crystals.
#1878
where would i go to find a couple of ko rcvr cyrstals, need two channel 03's 27.025 freq.
#1879
Check out...
http://www.shopatron.com/index/166.0.2010.2011.0.0.0
Direct link to KoPropo. You can buy from them direct.
Butter
Butter
#1880
thanks, but been there, they only list the even channels. and i don't see rcvr only crytals listed at all.
#1882
They sell odd and even. However, they do not sell just one crystal. Best of luck in finding what you need.
#1883
Hey does anyone of any new updates to replace the old serial port PC interface with a USB version for the ICS adapters? Just wondering. Thanks all.
#1884
there are plenty of usb to serial adapter that you can use. mine is from belkin
#1885
Ko Helios
Hi peoples,just picked up a EX-10 with 302f 27mhz receiver no module,would i be better going straight to spektrum with micro receiver or should i try to find a 27mhz module for this ,,is there any major dramas with spektrum some peole say there is not too sure
many thanx craig
many thanx craig
#1886
#1887
many thanx craig
many thanx craig
i have a helios with spectrum and its ausome. no worries about frequencies.
#1888
many thanx craig
many thanx craig
#1889
#1890
Hey everyone, I'm having technical difficulties with my ICS PC adapter, whenever I connect the Helios or the VFS speedo to the adapter, I get the error messages stating that the device is not connected. I made sure the com port number matches the one that is stated in the device manager. Can anyone offer up any advice or suggestions? Thanks.
