Corally RDX Phi 09
#482
I haven't dropped the $$$$$ for the "lipo" weights yet.I will on my next parts splurge.In the mean time here is a little trick I learned from one of my local track Corally guys(aka FABMAN). It kicks the battery out about a 1/4" and the car balances sweet. I used the battery strap and dremeled the holes in it a little(make the holes slotted) to line up with hole in the chassis that I used. Then I have to use Battery tape for the battery of course.
#483
#486
Yep. I really like the weights in the chassis. I can balance my car perfectly with them. Although Brad Johnson says to try add the 25g weight behind the battery. He says it helps offset the weight of the motor. I still need to get one myself.
Brad if I am incorrect, feel free to correct me.
put it on both the hudy balancing points and scales under each wheel and i can tell you its pretty close.... also i use an lrp motor cooling kit and i made myself up a carbon motor guard.....which helped distribute the weight evenly
#488
Hey guys check out the new editable Phi 09 set up sheet found on the Corally USA website. We have been working on this sheet for a couple of weeks. Hope this is what everyone was looking for.
Thanks - Brad
Thanks - Brad
#492
What bodies are everyone running right now? We are getting ready for outdoor season. Just curious to see what others are running ...
#494
