Simple Green
#49
So if simplegreen is just a cleaner and paragon is not allowed, what is your choice for traction compound on sorex tires?
#51
A bit off topic, sorta...errr...anyhoo
I placed Simple Green on a small plastic container and took it to the track with me. I used a small piece of cloth, dip it onto Simple Green and wiped it on my Foam Tires. Being lazy and all, I took the now dirty piece of cloth and dumped it into the container full of Simple Green and guess what, the concoction fizzed just like soda!
When running the car, I did notice a bit more grip on the tires but it only lasted a few minutes. But hey, I never knew Simple Green would react on Foam Tires that way.
#53
how about wd40 guys?
i spread it to my foams but i have not run it yet.
they are very sticky now.
#54
When I tried simple green w/ rubber tires on a permanent outdoor asphalt track, the tires were tacky after wipe off. The car handled as if there was a residue left on the tires; response was slowed and a combined push front and rear existed. Other drivers used it regularly, some as an additive and some alone.
#56
Simple Green right after you come off the track and wipe after 5 minutes or so, then apply your traction compound. Consistent traction (though not as good as WD40) all the way through the run, and the tires don't seem to lose their stickiness as they wear.
#58
WD40 seemed to make my tires VERY sticky after 10 minutes, but traction seemed to drop off about 3:00 to 3:30 into the 6 minute run.
What rubber tires was simple green applied to, and was it the concentrated stuff
Cheers Malc TCCFM
