TA-05 ver.2
#800
#801
Ta05 v.2 set up
Hi guys, just bought a ta05 v.2 for our Tamiya Nats. Is there someone who can suggest a good setup for std car,motorized by a bl system Carson dragster sport 12t. Only hop up admitted are: trf fluorine damper(53571),stabilizer bar F/R (53842),alu joints(53919), 27mm springs (53440) and type b tires. The body I have chosen is Nsx one. Tnx in advance!(races on asphalt tracks,medium-high grip).
#806
Last weekend i participated in the super stock race where brushless motor of not less then 9T was allowed. My verII was lacking of spareparts so i decide to give my 416X a opening run alongside drivers using 1 416WE, 4 TA05-IFS, 1 regular TA05, 1 TA05 verII, 2 X-ray T2 '09, 1 HB Cyclone-S, 1 HL 518 and 1 Vantex ( clone of the 416). Was amazed at how most of the TA05's was able to keep up with the 416's on our medium high speed track. At the end of the day the top ten cars to finish the rest was lead by 416's, followed by in order IFS, TA05, verII, HL518, X-ray's. I must say the TA05's gave most of the pressure on their rivals during qualifying eventho i myself had the pressure from my friend who was running an IFS and a verII. The TA05's are definitely build for stock and super stock class.
#807
I just picked up a TA05 V2 from my shop. I plan on making it a drifter.
What are the first must have upgrades for this car?
What is a good brushless setup to run in it? Are the EZ Run systems any good?
#808
Get some spares on the knuckle and king pin. These are the ones likely to go first. If you have the budget, get the universals for it and aluminium outdrives. The Ezrun systems are good as long as you intend to use it for drifting alone.
#809
Can someone post a link of where I can get an EZ Run system? Also, which one should I get?
#810
