TA-05 ver.2
#2146
I can't really comment on spur/pinion(I use 64 pitch in my touring cars), but these washers will work to space out the VTA wheels... http://www.speedtechrc.com/store/ebp...id=613&id=7158 .
Or, you could use what I use, which is this: http://www.speedtechrc.com/store/ebp...nid=615&id=823 , that eliminates the need for any spacers to make the wheels clear everything....
I actually think I got those wheel spacers a long time ago but I couldn't figure out where/how to fit them on. I'll deffinitly be getting those 6mm thick wheel hubs for the rear wheels.
And cdwilliams, that's the same range I was planning on going for. Was thinking on trying 46t-50t pinions. Maybe even down to 42t.. from 3.5 FDR -4 FDR..
Is 48p better for VTA? What would a good spur tooth count for 48p gears?
#2147
48p is more durable, since the teeth are bigger. They are supposed to be easier to get a good mesh on as well, due to the size. Although I haven't tried them yet.... 64p is supposedly quieter, cooler, and more efficient. I only run indoors though on carpet though so I'm not really worried about anything making its way into the gears and chipping teeth. So I'll give it a go. I picked 82/50 to mimic my current VTA setup. It's almost exactly the same ratio even though the gears are wildly different. I'll let you know how it goes.
#2148
I've decided to risk it and just ordered the hubs and 64p spur and too many pinions.. Need to have my car set-up hopefully before the 30th and have a ton of work to do..
But still let me know how the pinion fits because I'm still worried about that!
#2149
I run a 96t spur with a 47t pinion, and have room to gear up a tooth or two. An 82t spur should net you a lot of room for larger pinions.
#2151
Zac,
Here's what it looks like...
48P (left 35pinion/60 spur) vs 64P (50pinion/82 spur)
and then here's how it looks mounted. There isn't much room available to get farther to the right with the motor. You might only be able to get a couple teeth smaller on the pinion.
#2152
Zac,
#2153
hi those who have converted the ifs setup to standard, have you noticed a difference and are you lap times faster or slower, any info on this issue will help thanks
#2156
I have finally rounded up all the parts to accomplish the change to upright shocks. My reason for doing so is to make tuning easier. I've read the manual on tuning front shock when using IFS but think upright shocks might be simpler or offer a greater range of changes.
If there was a chance of a performance improvement, that would be very welcome.
#2158
When using upright shocks I had the TRF shocks on there and had the lower ball cups wound as far up the thread as possible. Even wound the thread through the lower ball cups by accident at one point to try and get the front ride height down to a decent level. Not sure if this issue would happen for everyone converting to upright shocks, but I don't see any way around it besides getting shorter (ie. crappy, non-TRF) shocks.
#2159
For me the conversion was the best thing I done to the car.
By eliminating all the free play in the multiple linkages in the IFS setup the car is more consistent, if only the driver was the same.
I don't have any ride height issues with mine, mainly adjust it with different springs & position of where the shocks mount.
Cheers
Rob.
#2160
I was also wondering if the tamiya 417 rear ball diff will fit the ta05 ver 2, if anyone has tried it please let me know thanks
