-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
AudioStylz 07-10-2013 07:28 AM
The spur gear shaft where the main shaft connects both diffs, without the center shaft I have some play in that area. On all of my TC3's and I've had 5 or 6 total they all had this similar play in that area. Never had an issue with anyone of them either.
Rodarbal 07-10-2013 09:24 AM
Originally Posted by misplacedtexan (Post 12334194)
Is this normal? Can someone let me know?
I haven't had issues with the rear, but I've had similar play with the front diff. I swapped diff housings to an older one that I had as a spare and it eliminated the play. Not sure if there were some "bad" housings made for these cars, but I wonder if you just happened to have two sets of rear cases that are more open.
misplacedtexan 07-10-2013 10:49 AM
Originally Posted by Rojna (Post 12334456)
Its not normal for the shaft to have play when the diff is mounted in the car and that shaft is supported by 2 bearings, 1 in the diff case and 1 on the chassis.
It is normal for it to have play when the diff case is out of the car and the shaft is supported by 1 bearing at that time.
Appreciate the help, this was in pieces when I got it, and I was finally able to round up most of the parts it was missing, and the outer bearing support was one of them.:o
Thanks again for your help Rojna!
Rojna 08-28-2013 01:38 PM
My new TC3 for VTA, this one will be set up for asphalt, chassis was cut out a little to add flex.
http://rcactionpics.com/gallery/2013...5_2013_027.JPG
misplacedtexan 08-28-2013 01:50 PM
Where did you get the center brace and battery hold down from?
christophed83 08-28-2013 01:55 PM
nice job.
Rojna 08-28-2013 02:07 PM
center brace is from a TC6, just cut down a little, I cut out the webbing in the center of the chassis, top brace is there to protect the drive shaft.
Battery brace is from ae http://www.teamassociated.com/parts/details/31039/
Rojna 08-28-2013 02:25 PM
1 Attachment(s)
Here is a pic of the bottom, all done with a dremel.
bullet100 09-04-2013 12:56 AM
Delete
JMURACN 10-04-2013 05:51 PM
I have a tc3 factory car, niftech front and rear diffs (and rebuild parts), titanium shaft,full niftech bearings, niftech cvds...PM me if you are interested
Bikerbob 10-05-2013 05:00 AM
So Rojna its been a month, how are you finding your tc3 vta? been running it?
I found the tc3 still competitive in VTA. The guys who will spend themselves on new T4s etc.etc.. and are good drivers are hard to keepup with.. but whats new?
James
Rojna 10-05-2013 08:13 AM
James
Ran it last weekend back to back with my FT TC4 in vta, times were pretty much the same throughout the day with my fastest lap going to the TC3 by.2sec.
The TC3 has the same chance of winning as anything out there, all about the driver :nod: now if I could only be more consistent and stay away from the walls :D
https://fbcdn-sphotos-d-a.akamaihd.n...49288658_o.jpg
Bikerbob 10-06-2013 09:47 AM
Well guys, just sold my TC3 to someone new who will be using it for a new driver. Love this car for that.
Thanks for all the tips and tricks.
kylecav 10-20-2013 10:47 AM
Does anyone know of a company that has a carbon chassis still in production? I am trying to set up a second car.
IndyRC_Racer 10-20-2013 11:44 AM
You might try this company - Xtreme Racing (http://www.xtremercracing.com/TC3302.cfm)
