How much are you looking to get for the BMI chassis? I see they offer different colors, which is yours?
I believe they are only making them only in black now (gloss not satin) I have an extra satin black - the top in in exc cond - bottom chassis has typical asphalt marks - would trade for a couple f and f+2 front arm mounts and a couple sets of front and rear arms....if interested..........about $40 worth of parts....chassis has nerf wing also.....
SHE WILL NEVER DIE NEEEEEEVEEEEEEEEEER :lol: i got 2 one i race each week and one i drift when ever i can long live the TC3 :smile:
Do you have digital photos of the chassis that you can send me? If it looks good, I may agree to your request. Is the chassis straight?
[email protected] Thanks |
i also really want to get a BMI top plate for my tc3 but i was just thinking to put the FT tc4 top plate on my tc3 (i know all what i need already :smile: )
nice chassis.. :nod:
do they sell the top plate alone? tnx |
do they sell the top plate alone? tnx sorry but who are you talking too |
This question was asked a few months ago. Did not find an answer so here is a list of parts required to convert a TC3 to TC4. The new chassis addresses 3 main problems. One the new motor mount should not warp the right rear corner of the chassis upward from motor heat. This messes up the tweak in hot climates where motor heat is more of a problem. The new chassis puts todays heavier batteries (high capacity NiMH) closer to the center of the car for better side to side balance. You get rid of the old steering which tends to build up dirt on center and causes loss of trim. The old rack can be cleaned regularly with the backside of an X-acto knife. Anyway I got a good deal at Stormer as the graphite chassis and chassis braces and shock towers came together in a kit at a reduced price.
ASC31003 TC4STEERING RACK 1 $4.50 $4.50 ASC31010 TC4 SUSPENSION ARM MOUNT SHIMS BALLS. 2.95 ASC31022 TC4STEERING BELLCRANK POSTS ~ 1 $4.50 $4.50 ASC31025 TC4 SUSPENSION ARM MOUNT SET 1 $4.50 $4.50 ASC31111 TC4 Factory Team Servo Mounts, carbon 1 $3.95 $3.9 ASC31042 TC4 MOLDED CARBON COMPONENT SET 1 $24.99 $24.99 ASC31019 TC4 DRIVE SHAFT ACCESSORIES 1 $3.50 $3.50 ASC31046 TC4 MOTOR MOUNT: blue aluminum 1 $14.95 $14.95 ASC31026 TC4 Front BUMPER 1 $4.50 $4.50 ASC2225 NITRO TC3 BUMPER TOP BRACE 1 $2.50 $2.50 ASC2229 NITRO TC3 Steering RACK HARDWARE SET 1 $5.95 $5.95 ASC31024 TC41NNER HINGE PIN SET 1 $2.95 $2.95 Subtotal, excluding shipping: $80 Add 4 Asc 3916 3/16 x 5/16 ball bearings (diff bearings work) for ball bearing steering. $10.00 I finished the conversion of my TC3 to TC4 with Associated parts. Here are some additional items you might need as well as some additional items that are different on the TC4 ASC 2230 TC4 front Body Posts, The old rear ones will work. The fronts too if you want to redrill them. They will be oversized in diameter though. ASC7874 and 6926. These are 5/8 and 7/16 inch Socket head capscrews for the motor mount clamp. The old motor mount clamp from the factory team kit will fit, but the new one lets the motor breathe a little better. ASC 2229 listed above for the new steering links was short two bushings to work on the TC4 so you will need at least two more bearings or bushings 3/16 x 5/16. The New TC4 has thicker input shaft cups for the diff, but they are not larger outside diameter. The new driveshaft thus has a smaller ball on the end. The old shaft will not fit the new cups or vice versa. If your shaft is the least bit damaged get a new shaft and use the newer cups. Photo of the finished conversion on my post 10843. Here is a link http://www.rctech.net/forum/showthre...ge#post2064815 |
do they sell the top plate alone? tnx BMI used to sell the top plate alone. I'm not sure if they still do. I think theu just sell the complete kits now. |
y do u want a top plate for a TC3 :confused: ive had the one of my warpspeed off it and it did sweet fa. I cant see it stiffing it up anymore than it is its solid lol
Random ?: is the servo horn supposed to be vertical or horizontal and what about the ball cup? I want to make sure that I have that installed properly.
Random ? #2: when installing the receiver, what do you do to keep the antenna wire from going down through the hole in the chassis bottom so you can put it through the antenna tube? |
from the middle hole to the top whole the gap should be 3mm to the right if lookin from the front according to the book infront of me the top of the servo horn is 3mm to the right of centre hole
#2 i just used a screw driver when i install it to stop it going down but im cheap :lol: |
| All times are GMT -7. It is currently 09:00 AM. |
