-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
crACkeD ChaSsiS 02-05-2005 08:58 AM
question
primusblowsgoat-hey man do u see any difference between the aluminum shaft and the stock shaft?as in performance?
primusblowsgoat 02-05-2005 09:25 AM
i dont really know, ive only driven the tc3 a few times recently, and only once with the alum shaft, but there were so many other things wrong i couldnt tell you
RC Buddah 02-06-2005 07:22 AM
put my brushless motor in my FTTC3 yesterday and WOW amazing! the only thing i ran into was changing the spur gear.....u ahve to take out the whole rear end..but i guess its okay..the car is super fast though. i cant wait to run it at the track!
crACkeD ChaSsiS 02-06-2005 07:26 AM
brushless motor
u guyz have a brushless class?
kh15 02-06-2005 06:33 PM
is this a one-way diff? http://www2.towerhobbies.com/cgi-bin...?&I=LXDGD6&P=7
primusblowsgoat 02-06-2005 08:38 PM
no thats just a solid axle, like if you glued a diff together
RC Buddah 02-06-2005 08:58 PM
Re: brushless motor
umm im not sure...ive been running offroad...and i just run for fun during practices..thats it..
RC Buddah 02-06-2005 09:15 PM
hey guyz....im trying to solve this problem...there are holes on top of my diff case that show the diff...waht im worried is that dust/tiny rocks will get into the diff...is it okay to put some silicone on top of it so it would be sealed?
Speedie 02-06-2005 09:31 PM
I put a small screw in the hole but some silicone will work great.
kh15 02-07-2005 12:31 PM
yea whats that about, i have to clean mine out all the time, during the summer but i dont worry about it when i run on carpet in the winter, i will just shove a screw in it, but my tc3 is on the shelf now cause those stupid plastic diff cases are all stripped out so i have to get new ones:flaming: :cry:
any one know of a site where i can get a one way for my tc3?
JWATT 02-07-2005 12:37 PM
Originally posted by kh15
[B]yea whats that about, i have to clean mine out all the time, during the summer but i dont worry about it when i run on carpet in the winter, i will just shove a screw in it, but my tc3 is on the shelf now cause those stupid plastic diff cases are all stripped out so i have to get new ones:flaming: :cry:
Just buy 5/40 screws, problem solved!
crACkeD ChaSsiS 02-07-2005 03:24 PM
one-way
i dont know if this will work 4 the tc3 but it may!(one-way)
http://www2.towerhobbies.com/cgi-bin...ay&FVPROFIL=++
kh15 02-07-2005 03:33 PM
i found one thanks for your help
http://www.carttonic.com/catalog/ind...54,10280,14149
TimmyMontoya 02-08-2005 04:01 PM
Can anyone direct me in the right direction for a setup with 28mm plaids and purple tires?I will be running on carpet also... I just got a used tc3 and need some help... Thanks in advance!!!
marzin 02-10-2005 02:53 AM
Mod to droop screws
Hi Guys,
Mod to droop screws?
I hv got a TC3 without droop screws, still using the shock limiters.
Can I convert the arms to use droop screws? Buy the Ver2 arms?
Any ggod ideas to go about it?
Thanks for any help :)
Cheers
