-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
scotwithonly1t 12-28-2004 06:58 PM
CVD's RUbbing
Does anyone have a problem with the rear CVD's rubbing the springs? I have the car length at the middle position (spacer on either side). I know they're rubbing cause the CVD's got a shiny spot on them. Is something amiss with the way I put the car together? Thanks for any help in advance.
Nova F1 Racer 12-29-2004 08:04 AM
Re: CVD's RUbbing
I used a longer screw and washers on the top to move it away from the CVDs.
calstarjig90j 12-29-2004 08:50 AM
Re: CVD's RUbbing
You can do two things here that I have done. Put another nut(ON TOP) on screw to make the top part of the shock move more to the rear or you can cut the wider servo spacers that came with the tc3 kits and place them in the same place as an alternative. As with the front if you use 2 or 4 degree castor I shave the c hub so that the spring cup and spring have free movement. I also do the nut or spacer thingee to the front shocks for clearance. When racing every little thing makes a difference.
calstarjig90j 12-29-2004 08:53 AM
Re: how long to soak bearings?
Originally posted by crACkeD ChaSsiS
how long do u guyz soak yur bearings in motor cleaner are watever u use to clean them in? and wat do u do afterwards?ny help well appreciated
Steven Alexander
however long it takes to get the gunk out. Break the seals and they'll really run free. Lots of maintenance though.
envious8420 12-30-2004 06:09 AM
Originally posted by SPZA
i was just wondering if anyone out there has any links to site of some set up tips for the TC3. i was looking for things like, battery mod, steering rack mod, and any others you guys have.
thanks
tc3 mod site
HK Racing Joe 12-30-2004 01:59 PM
wat upgrades u guys running ( driver shaft, chassis ect.) jw
rs911 12-30-2004 03:24 PM
? Steering rack tc3
:DHi guys just wondering does the nitro steering rack or tc4 rack fit the bmi graphite chassis
Speedie 12-30-2004 03:33 PM
The nitro rack will fit into the BMI TC3. Here is a link that explains how.
http://tpjexelby.tripod.com/NitroRackPics.htm
Red Z 12-30-2004 10:41 PM
I soak my bearings in STP Fuel injection cleaner overnight.
As to bodies, I find that the Alfa Romeo 2 from Proline is darn good. It's better than the C-5 for sure!
crACkeD ChaSsiS 12-30-2004 11:05 PM
top bumper brace
has ny1 tried the tc3 top bumper brace?if so does it help handling or?
Steven Alexander
PaZ 12-31-2004 03:46 AM
HKlosi---------- scroll down the page thats the upgrades i got until i get more money :lol:
redheat8 12-31-2004 12:33 PM
Little off the bearing discusion but has anyone tried the Light Speed motors. I put one in the TC3 and it's a rocket anyone else use one , RED
crACkeD ChaSsiS 12-31-2004 12:43 PM
with the regular composite tc3 kit and high end electronics.do u think a tc3 is overweight or undeweight?ny help well appreiciated
Steven Alexander
vtl1180ny 12-31-2004 02:51 PM
My TC3 weight 100 grams less than my Yok CGM... Both chassis's unmodifieds....
Red Z 12-31-2004 05:23 PM
My TC3 w/upper end electronics, batt., body is a shade over legal racing weight min. My chassis is unmodified.
