[QUOTE]Originally posted by Proficar403
[B]We also figured out how to get the arcor 19s to run in touring. Gear them so outrageously high that you can smell them from the driver's stand!:D I have never had so little run time left on a pack after running a 19 turn.[QUOTE] Wow... I was running 56mm tires and geared 34/96 int he club race and I turned 25 5:03. Wonder how fast I could have gone if I geared up a little :) Must have been my packs making me a rocket down the straight. |
Re: Wheel eating lower shock mount
Originally posted by oldrc12e Help!! My rear wheels are eating into the lower shock mount on my TC3. I'm running Jayco double purples on the rear and seem to have plenty of clearance. There doesn't seem to be any excessive play in the wheel bearings or anything. Seems like the wheels are really flexing in the corners. Is there a stronger wheel/tire that I can buy that is similar in traction to the Jayco? Car is a team car which is a little on the heavy side. Suggestions???? Jack I currently use TRC Purple 30mm rears and Plaid 28mm fronts with no binding or rubbing. Hmmm. :confused: This one is interesting. |
What is the width of the wheel? Are you running 28mm? 30mm?
I currently use TRC Purple 30mm rears and Plaid 28mm fronts with no binding or rubbing. Hmmm. This one is interesting SpeedyTC3, The wheels are 28mm. I have been seeing marks on the inside edge of the wheels but couldn't find where they were rubbing. Last weekend I ran with the 19 turn guys and the wheel really wore into the shock pivot. Maybe I need to buy some TRC tires/wheels. Maybe they are stronger. Jack |
Wheel Rub
1 Attachment(s)
Here's a picture.
Originally posted by DaveW Proficar403: Arun, i was glad to see you do so well for your first big race. The jitters go away man! As far as your screw coming loose, i think i would have to give that screw a slow death by rust "execution"... or at least beat it flat with a hammer and use it as weight for next year!! Its always the simple crap that gets us! :flaming: As far as the "event" on the straight in my last qualifier, my RPM bumper now shows ALOT of BLUE! :lol: Back to the "dyeing board". :blush: See ya soon for some hot laps! - Dave Originally posted by mike_Webb Wow... I was running 56mm tires and geared 34/96 int he club race and I turned 25 5:03. Wonder how fast I could have gone if I geared up a little Must have been my packs making me a rocket down the straight. |
Re: Wheel Rub
Originally posted by oldrc12e Here's a picture. looks like the wheel came loose and rubbed it. I run 30mm rear and don't have any rub. but I have seen it when a wheel nut comes loose. |
Try 38/96! You could cook a steak on that thing, even after waiting to marshall:D ! Some even ran a 39! For most of my runs I was geared 35 or 36 / 96 |
Re:Wheel Rub
davepull,
I wondered about that but all the wheel nuts were tight. I use the Trinity nuts and locktite them every run. Suppose the small Trinity nuts are letting the center hub flex? Jack |
which wheel nuts are you using???? 8-32 lock nuts? or the flat purple ones?
8-32 lock nuts.
Jack |
I think they are steel. Take a 7/32 socket. Pinch thread type, not the ny-lock aluminum ones.
Jack |
New TC3?
I have heard that members of Team Associated ran a "new" TC3 at the snowbirds. Does anyone know about them? What I have heard is that the chassis is thicker and the batteries moved in. Anyone know any more?
:tire: |
no they all ran the same tc3 we can buy
I spent a lot of time with Barry trying to get my car hooked up and he had the same old TC3
Re: New TC3?
Originally posted by JSJ Racing I have heard that members of Team Associated ran a "new" TC3 at the snowbirds. Does anyone know about them? What I have heard is that the chassis is thicker and the batteries moved in. Anyone know any more? :tire: |
| All times are GMT -7. It is currently 06:58 AM. |
