Body Posts
Kraig,
I've painted and trimmed alot of bodies, Stratus in particular. I'm fairly certain we use the 3rd hole from the bottom to mount to which means the 4th hole is where the body clip goes. Any lower than this and your tires(under a soft setup) will rub against the body causing steering issues. Set the body level and trim it at the mold lines in the lexan. I may be off by one hole, but that should help you figure it out... Good luck, come over TCHR in Minneapolis if your in the area. |
Re: servo saver
1 Attachment(s)
Originally posted by Buda My servo saver came loose durring my last race so I had to adjust it. I didnt have the manual so I tightened it then backed it off 1/2 to 3/4 of a turn later I toasted that servo what is the best way to adjust it? On the file that's attached with this post you can see what's my adjustment for the servo saver. I use a Futaba 9450 servo and I needed to adjust on the tight side. |
Thanks guys, I am looking for a base line and see how I compare my work to others.
Greg, I might just have to do that. Don't talk to Schaub though, he will tell you I am a hack. :) I can't remember, do you guys run foam or rubber over there? A bunch of people from your club came to race with us, guess we should return the favor.:) |
Thanks for the info TP and Corse R, I just installed the BRP front bumper and nerf wings how much do they help protect theose front arms anyway? I dont drive very smoothly and our board are murder, one wall is concrete indoors and they use used motorcycle tires on some turns as well. I busted a ouple arms and want tp stop it will get expensive. Also what about the rear bumper?
One more thing I need just a touch more rear bite how much of a differance is it to shorten the wheel base from the midle |
Buda
I run the BRP wide bumper and nerf wings and it really helps when you have a rough brush with the boards. They put some nice dents in your body, though! |
Originally posted by Buda I dont drive very smoothly and our board are murder, one wall is concrete indoors and they use used motorcycle tires on some turns as well. I busted a ouple arms and want tp stop it will get expensive. Also what about the rear bumper? Maybe you continue to break some arms, but slowly you start to drive more precisely and some day you'll break zero. P.D: The last weekend a friend of mine slammed a TC3 to a concrete wall it broke in two parts the chassis (radio glitch). I'll post the photos ASAP. :cry: |
TP > email address?
Do I need servo saver?
What is the best servo saver? |
have any of you guys used aluminum arms and mounts? where can i get replacement delrin inserts and balls, similiar to the ones that are included in trinity aluminum suspension parts for the tc3? thanks for any info!
Originally posted by rcruv Do I need servo saver? What is the best servo saver? |
1 Attachment(s)
Originally posted by marvi have any of you guys used aluminum arms and mounts? where can i get replacement delrin inserts and balls, similiar to the ones that are included in trinity aluminum suspension parts for the tc3? thanks for any info! BTW the al shock caps are an option from Associated. In this moment I don't have the part no. (sorry for this). |
Marvi, I have not used the aluminum arm and mounts but I have seen a lot of racers use them. I have also seen them struggle with car setup as well, only to find out they bent an arm. Whenever you replace something with metal you run that risk and the energy applied when in an accident has to go somewhere and I would rather replace an arm or mount than a chassis.
ASC1598 for 4 aluminum shock caps $11.95 ASC6439 for 1 aluminum shock cap $3.00 |
When using the aluminum shock caps remember to use the o-ring designed for the aluminum cap not the one that comes in the kit for the composite caps. Otherwise your shocks will leak. Unfortunately I can't remember the part number off hand.
Hello......
So....this is where everyone from rctouring.com went.....hello all..I'm back...:D
Re: Hello......
Originally posted by TC3GTR So....this is where everyone from rctouring.com went.....hello all..I'm back...:D It's alive!, it's alive!.... :D |
| All times are GMT -7. It is currently 01:09 PM. |
