TC3 Forum
#6106
Silver Cans
Hi
Just wondering how to fit a silver can in the TC3 as the motor mount cam is too small for the motors.
Cheers
Cheers
#6107
you need to remove some of the material from the cam. dremel, drill, mill, whatever you choose, try to do it properly and take your time. i haven't done it myself, but i can probably explain it if you need more details.
#6108
TC3 Featured on TechTV!
I just found out about this, and I didn't see any previous posts about it, so I thought I'd put it up...
less than a month ago, Cliff Lett appeared on the TechTV show, "The Screen Savers" to show off the world's fastest R/C Cars (the 80+MPH TC3 and the 111MPH 10L3 prototype). It was a pretty neat to see R/C Cars featured on this show. The show originally aired July 14th, and was recently rebroadcast on August 30th... here's a link to the story from thier website, which includes a video of the segment that aired.
TechTV
Be patient if the video link doesn't connect... sometimes their Media Servers get bogged down. Oh, and when you DO see it, try not to laugh... these guys definitely have never tried R/C before...
TechTV
#6109
That was pretty danged good!
I'd heard, though, that the actual 10L30 they used disintegrated - I thought someone like TonyP said that. . .can't remember. It was a while ago.
Still, not a bad bit - better than CC doing his "thing". . .
#6111
berger, you mean in that vid?
cause his tc3 had a lehner basic xl4200 and a schulze controller...
also, this vid is also on www.rcpics.net
#6112
No he doesnt, if you follow the link on the above page it takes you here Linky where it states that his TC3 has the following equipment;
His L3 has the brushless system.
Transmitter Airtronics Caliber 3PS
Receiver LRP Phazer
ESC LRP V7.1
Batteries Reedy Zappers 2400mAh (14 cells)
Motor Saiko Racing machined motor can with neo magnets and Reedy 12-turn double armature, brushes and endbell
Servo Futaba S9102
Receiver LRP Phazer
ESC LRP V7.1
Servo Futaba S9102
#6113
Originally posted by stormperson
bubbles- who makes those bearings? and ya, its for carpet only.
trinity- how long does your drivetrain spin for with foam tires or rubber tires on? also if you spin the bearing with your hand how much does it spin(ie a rotation, two rotations... etc)
thanks!
thanks!
air as in take off all the sheilds, it is not a company or a type of berring
after about 6 months of no rebuilding the drivetrain, MY car will spin for 10 seconds with rubber tires
not a lot, but still pretty free
#6116
believe me, I know about his cars...
his speed run was with brushed.
but notice I said "you mean in the video?"
in the video he had BRUSHLESS in his tc3 when doing the runs
#6118
Johnny, the stuff dries to a wax so use it sparingly. You could test it out on an old ring gear if you have one or just barely squirt some around the ring gear once, do the same for the pinion and you should be set.
