TC3 Forum
#6121
Well you could but first you would have to have gears custom made and then probably new gear cases. Why would you want to anyway?
#6122
Re: lowering the internal gear ratio
Originally posted by OHBRAD
Hi,
does anyone know if you can lower the internal gear ratio of the TC3, just curious
regards brad.p
Hi,
regards brad.p
the 2.5:1 is fine, why would you want to change it?
you can put some r2 gears in the boxes, but you would have to re shim it a lot
it is not like a tl01, you cant just drop in some integy speed gears and have the car go faster or have better acceleration
#6123
alright everyone, since this thread hears it first,
I just got the 19 turn quadmag in the mail today from AE, I will post pics and how it performs at the track, sometime tomorrow evening, it looks SWEEt though
#6124
BUbbles or you could just by a YOK. See ya at the track with ym new batts.
#6125
Transmission cases
Hi all,
I am in the process of building the kit and the Diff does not fit into the xmission case easily. When I snap it into the xmission, it seems that the bearing is putting pressure in the outdrive hub. Therefore there is too much friction. Any hints or has anyone seen this before?
#6126
Do you have the right amount of shims on the correct side of the differential? If so, don't worry about it and run the car, they will loosen up.
#6127
The diffs and the shafts were assembled correctly. The gear teeth side of the diff bearing fits nicely but the opposite bearing needs a snap to fit into the case. I think the SNAP is causing the bearing to put pressure on the diff outdrive hub causing the rubbing
#6129
K i got a TC3 but i got a problem.. i think its my pinion and spur. it makes a clicking sound whether i roll it on the ground, or actually use it. should i just take it to my LHS with a charged battery to have them check it out? thats what im going to do, i just wanna hear from you first
god dam why does every RC forum have vB.. i dont have $180 god dam dollars lol
#6130
hockey- most likely one of those gears is gone and needs to be replaced because it either got a stone in it, or most likely the mess was improperly set.
#6131
well bringing it into my lhs to get fixed shouldnt be a problem then.. some of them working there know their RC, so lol
on to the vB topic again.. anyone have a spare $180? :-p lol jk
#6132
am i missing something
#6133
Don't feel alone MisFitz
#6134
