-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
IMPACTPLAYR 05-09-2003 11:04 PM
No, I have never had any problems
Hooked 05-09-2003 11:08 PM
Thanks man ... I'm gonna give it a try ... I don't often have to pull the hingepins out, but when I do it typically needs to be done in a hurry ...
IMPACTPLAYR 05-09-2003 11:17 PM
Just remove the material that goes behnd the diff case, but leave the material that comes in contact with the front of the case.... this protects the pin mounts and pins from impacts....
Hooked 05-10-2003 07:13 AM
Thanks ... I'll do that.
Coxy 05-11-2003 07:50 PM
How much droop are you guys running front and rear for Carpet. Also how much droop are you running in general and what surface.
Coxy.
johnny55 05-12-2003 03:50 AM
Slow on the sweeper
Hey I was racing this weekend at socal and my car seemed really slow on the sweeper. Im not sure if my car was slow or if it was just me. I just thought Id ask to see if someones experienced this yet with their TC3. I was running a one way for the first time. What should I check for sweeper action!!??:weird:
HeavyD 05-12-2003 05:46 AM
What are the best rubber tires to use on outdoor asphalt?
CRASH 05-12-2003 05:53 AM
Coxy
For carpet racing I am running 6 front 4 rear for droop. I am basically running the factory setup for carpet. The car is planted extremely well.
Later:)
DaveW 05-12-2003 07:08 AM
Ok guys... my Yok one-way for the TC3 and the bladder caps are on the way from SpeedtechRC. Is there any difference between the standard AE one-way of old.. compared to the new Yok one way... other than durability? Can or should i use a different lube in the bearings than the grease that is in them? Are there parts available from Yok for the one-way... or if there is failure... do i simply buy another? As far as the caps go... i know there is differing bound/rebound characteristics with bladders in shocks, and would like to know if anyone has experience building these for asphalt, and could give me some pointers. "Foam volume compensator" ...yes or no? My experience with bladders came and went with an old HPI pro of years ago. Since then i have used bleeding screws in the caps. So any help would be appreciated.
- Dave
CRASH 05-12-2003 11:01 AM
DaveW
The Yokomo one-way is identical to the new Associated one. I have an old one-way by Associated and my lhs just got in the new Associated one-way and the Yokomo one-way. They are identical in everyway.
I have not tried my Yokomo bladder caps yet. Be interested in hearing your results.
Later:)
wiley 05-12-2003 12:23 PM
Hi all
Havent seen much of the AE guys like tphalen lately....might have been busy with their B4s:D :sneaky:
BTW what's the difference between the new oneways and the older ones
thanks
ZER01 05-12-2003 12:33 PM
- Dave
On the subject of the bladders, all I can tell you is they hold their rebound alot longer than the AE foam compensators. There's been cases where I hadn't changed my shock oil for like 15+/- races and the shocks with the yokomo bladders caps had exactly the same amount of rebound as they did when they were first built. :)
IMPACTPLAYR 05-12-2003 01:04 PM
I don't get much practice when there's a lot of rebound in my bladder..... keeps me running to the bathroom.....LOL
ZER01 05-12-2003 01:18 PM
Sorry Impact, I meant the shocks hold their rebound alot longer.
wiley 05-12-2003 01:56 PM
LMAO:D :sneaky:
