TC3 Forum
#5026
This may sound stupid but I have seen people do it before. Check to make sure you do not have a plaid on one of the rears instead of a purple. It will make your car silly loose.
Paul
Paul
#5028
Chicky was referring to the fact that you may have different hardness (shore rating) of tires on each side of the rear of the car ... something to check ...
#5030
Any news yet Johnny on your radio settings or suspension set-up?
#5031
i have a ko mars r that i switched to defualts and even when i turned the left balance all teh way down it still does it. and i had someone untweak my car but for some reason when i go straight and try to turn left it would just wipeout but on teh right it would turn soo good , good thing my sweeper turns right. lol
johnny
johnny
#5032
I don't mean to insult the guy that helped you with the tweak on your car ... but does he know what he is doing?
#5034
A bearing locked up on one side of the car would have an effect on the steering ...
#5035
guys, would just want to ask what pinion gear should i use for a GM3 motor? thanks!
#5036
I don't have any experience with a Green Machine 3 ...
But ... for someone to respond to this, more info is needed ...
-type of car (I assume it's a TC3)
-48 or 64 pitch
-type of track (i.e. long and flowing ... tight infield ... long or short main straight ... etc.)
-driving style (i.e. lots of stopping and starting from hitting boards ... free flowing through corners ... etc.)
I could probably think of more variables ... but I'm sure you get the idea.
-48 or 64 pitch
#5037
I forgot to add ...
-Spur size (# of teeth)
#5038
will be using a 64pitch/72 teeth spur gear. will be playing at 2 tracks.. one is carpet, tight.. the other is asphalt and track is flowing (i think..)
#5040
oops.. its a 48 pitch spur gear, not 64..
