TC3 Forum
#5012
Re: TC3 One-way
Originally posted by seamus0g
Anyone know what happened to the ae one-way for the TC3? I can't find any info about it on the Ass site, and it doesn't show up searching on Horizon and Tower. Has it been discontinued? I found a part number searching on Google, 3938, but such a part number doesn't show up on the ae parts list or any of the online catalogs. What's the deal? Thx.
#5013
Thanks for the info guys. Also I just was informed by my LHS that Ass changed part # to 3978... which might be the Yoko in an AE package a la the NTC3 HD oneway... but who knows.
#5014
HI EVERY ONE-
Ive just got myself a FT TC3-i got it pre-built-but when i hold it & put the power on it vibrates like hell.?.
Is there any waY i can fix this.??.
also the main shaft has 3/4mm paly,is this normal
Please help
steve
Please help
steve
#5015
Re: TC3 One-way
I believe it has, because they are making a new H.D. one or something, and also you can buy the Yokomo Heavy Duty one.
Check on www.speedtechrc.com they have it
#5016
The vibration could be a few things the most common one is your tires are probably out of balance. Just like a real car, unbalanced wheels can cause vibrations. I use an airplane propeller balancer to do mine. They don't have to be perfect but when you glue up tires, there usually is a spot with too much glue or the tired and or wheel them selves will have a heavy spot. Just try to counter the heavy spot with some lead tape. It works nicely.
#5018
the tyres & wheels have not been used-& it vibrates when i hold it in my hands.?.
The car is also brand new..
thanx for the surgestion
regard's
stevie
regard's
stevie
#5019
Selling everything - just to let you all know!
On eBay..........
http://cgi.ebay.com/ws/eBayISAPI.dll...gory=2565&rd=1
Feel free to contact me. Thanks!!!
#5020
Originally posted by Stevie
HI EVERY ONE-
Please help
steve
HI EVERY ONE-
Please help
steve
Put a drop or two of oil in the Diff out drives wher the dog bones
go in. They bind up sometimes and cause the vibrations.
#5021
Slowly apply power while holding the car ... does the vibration increase proportionately to the drivetrain rpm? or does it start to vibrate all at once?
Is there any noticable runout in any of the visible parts? For instance, the spur gear or input shaft cups being out of true ...
Remove the drive shaft and apply power ... this will help to eliminate the drive shaft and the front dif as the problem ...
Let us know how these suggestions turn out.
#5022
Can any one help me. My car when I make left turns the car wants to spin out but when I make right turns It is ok. I check and recheck the tweak went over the whole car I even bought a new chassis and it still does the same thing I checked the rear toe in and it is fine any help would be greatly appreciated
#5024
That's odd that your car would turn left sharper than right ... given that the tweak is compensated for of course ...
The TC3 has more steering throw to the right than the left by design, but that does not explain what you are experiencing ...
Have you checked your radio steering end-points? If the end-point settings are messed up you could be physically moving the servo farther left than right.
#5025
Do you have access to a set-up board? You could have front suspension asymmetry ...
