thats actualy a good idea. mine were a pain in the but to put in. i used a rubbermallet to get them in. If it is realy hard to get in, I would use a body reamer or exacto and make the edge of the hole (where it starts) and make it a little bigger. it should help alot. If if it realy doesnt fit u can use a drill bit and bore it out, but i highly recomend not to do this adn would not condone it.
I sprayed Teflon and spun the pin in the arm with my dremel. It is extremely smooth, no binding now.
Originally posted by ovalnator Trips, where in NY is Bayside????? Where is Meridian? Trips |
Originally posted by Trips It's in the southeastern part of Queens, not far from the Bronx. Where is Meridian? Trips |
ITS RUNNING
Finaly I got my tc3 running. man this thing is fast. It is so fast that it just spins the tires. I love doing doughnuts in my living room.
Re: What about inserts?
Originally posted by TurnNBurn Almost forgot about inserts... I 've been using Jaco Blue. How do you tell if you need to use a harder or softer insert as opposed to changing the tire?:confused: - ProLine 1095 H13 w/ Yokomo ZR37 soft inserts. Soooo smooth. - ProLine 1095 S3 w/ Yokomo ZR37 med inserts or Jaco Green, blue ones are too hard. |
I agree that the TC3 is fast even with a stock motor, but I can certainly see I am not going to run my best stockers in it because the motors get SO hot. I will save them for offroad. Any recommendations on gearing for say a Rage or Paradox motor? I am also looking for a good concrete setup. It is concrete similar to sidewalk concrete. Pretty smooth too.
Originally posted by mystererc I agree that the TC3 is fast even with a stock motor, but I can certainly see I am not going to run my best stockers in it because the motors get SO hot. I will save them for offroad. Any recommendations on gearing for say a Rage or Paradox motor? I am also looking for a good concrete setup. It is concrete similar to sidewalk concrete. Pretty smooth too. Personally I prefeer to use the black one (remember, the black absorbs more heat than the blue). |
Thanks Corse, but...
What I was trying to ask was... If I know that tire "A" is the hot ticket for a particular track, what do I look for to determine if I need a harder or softer insert to go with it? Does surface play a role? If I just go with what everyone else uses for an insert, how do I know that maybe there isn't a better insert out there to try?
BTW, about the black heatsink... no wonder Mark Pavidis' winning car had the black heatsink on it... interesting! |
Re: Thanks Corse, but...
Originally posted by TurnNBurn What I was trying to ask was... If I know that tire "A" is the hot ticket for a particular track, what do I look for to determine if I need a harder or softer insert to go with it? Does surface play a role? If I just go with what everyone else uses for an insert, how do I know that maybe there isn't a better insert out there to try? BTW, about the black heatsink... no wonder Mark Pavidis' winning car had the black heatsink on it... interesting! - I have enough traction / I have enough tyre lasting? NO/YES -> Choose a softer insert NO/NO -> Choose other suspension settings (maybe, try to softer the suspension to get some chassis roll and get a little more traction). - I don't have enough traction / my track is bumpy: YES/YES -> Choose a softer suspension and a softer insert NO/NO -> Choose a softer insert and raise your chasis (more chassis roll). In few words: You want more traction, get a softer insert, your tyres last shorter but you have more grip. If tyre lasting is a problem, try the chassis roll trick. This is my setup for asphalt. Front: Cooper/Red spring/60wt/ piston #2 1º of toe-in in the steering 0º kickup 2º Caster blocks 0º Camber. Rear: Blue/silver spring/50wt/piston #2 2º of toe in (by the rear a-arm plate marked by 2-0) 1º Camber ProLine 1095S3 w/ Yokomo ZR37 inserts Beware, the car with this setup is pretty fast, but the rear is a little itchy and sometimes breaks loose, but in fact, is very speedier. If the car is too nervous, you can try to soften the suspension and switching to the 4º degree caster blocks. |
Originally posted by TurnNBurn BTW, about the black heatsink... no wonder Mark Pavidis' winning car had the black heatsink on it... interesting! |
hey guys, i don't have a tc3, but a cool idea for you guys if you guys haven't pondered about already.....the nitro tc3 utilizes pivot-ball suspension. wouldn't be cool to try to modify them to fit your electric tc3? hehehe. then the tc3 would be the ultimate shaft drive car.
Hi everyone, my TC3 has been acting really strange lately. Everything is OK when the front wheels are straight, but when they turn and i put on gas, the front wheels would start shaking and making noises? i can't seem to figure out what the problem is... any help would be great! thanks!
peter make shure that all the capacitors and doides are in place. It sounds like motor interferacne.
Originally posted by porkybmx hey guys, i don't have a tc3, but a cool idea for you guys if you guys haven't pondered about already.....the nitro tc3 utilizes pivot-ball suspension. wouldn't be cool to try to modify them to fit your electric tc3? hehehe. then the tc3 would be the ultimate shaft drive car. |
| All times are GMT -7. It is currently 05:53 PM. |
