Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 07-25-2011, 02:41 AM
  #5761
monkeyracing.cz's Avatar
F1 - WET RACE - final movie ...
http://www.youtube.com/watch?v=hGdUO2V10L8
(Watch in HD)
and "Behind the scenes" ...
http://www.youtube.com/watch?v=gi7KE6zT-2I
monkeyracing.cz is offline
Old 07-25-2011, 02:45 AM
  #5762
Luosi's Avatar
(Watch in HD)
Very nice, well done.
Luosi is offline
Old 07-25-2011, 04:27 AM
  #5763
mattwoodcraft's Avatar
coold vids i was wondering what you were doing to seal up the electronics and now i know
mattwoodcraft is offline
Old 07-25-2011, 12:49 PM
  #5764
gsxr0311's Avatar
Trader Rating: 19 (100%+)
nice video, next time you should get more cars in a wet race and film it. cool though.
gsxr0311 is offline
Old 07-25-2011, 01:07 PM
  #5765
thanks! I have to find more fools like me to put car on wet track.
But now I have some arguments, my car is in perfect condition after doing that. Electronics was sealed with plastic wrap and all bearings sprayed with TF2 teflon lube before shooting video. And everything is ok.
Old 07-25-2011, 01:22 PM
  #5766
lightfoot's Avatar
(Watch in HD)
so so so so so so nice..........
The whole thing is so well done from capturing the images to editing and music... very impressive....
lightfoot is offline
Old 07-25-2011, 01:55 PM
  #5767
connyw's Avatar
Does anyone know where to buy Benson decals for F104Pro
A second question: what is best rubber tires on asphalt
connyw is offline
Old 07-25-2011, 02:01 PM
  #5768
lightfoot's Avatar
http://uf1series.com/_sub_pages/old_...re_review.html
Old 07-25-2011, 02:24 PM
  #5769
connyw's Avatar
Now we talk tire test at a high level Thanks
connyw is offline
Old 07-25-2011, 06:06 PM
  #5770
rtypec's Avatar
Default F104 X1 Build - Steps 10-13
Steps 10 through 13 involve assembly of the servo saver and installation of the servo and electronics trays.
Parts for the famous or infamous Tamiya heavy duty servo saver
If you look carefully, I went back to step 9 and flipped the ball connectors on the aluminum servo horn. From my experience with the F04, I liked the way this setup felt on track. Additionally, this may help offset any ackerman effects that occur due to extreme tie rod angles. This is something that you should test on your own and decide which way feels better because of different driving styles and indvidual preferences on how the car should feel.
Servo installed
I trimmed off some plastic near the front front of the servo holders in case I want to play with additional steering geometry in the future I have in the past, but I actually prefer the stock servo position. This is one of those "just in case" moments.
Adjuster clearance
There's not much room, but the adjusters clear the servo and mounts with no binding or rubbing.
Also, I've given up on providing weight comparisons between stock and hop up hardware for individual steps. It's a work multiplier and slows down the build tremendously. Besides, I think we should get the idea by now; the car will be lighter than stock
Attached Thumbnails Tamiya F104 Pro!-11_parts.jpg   Tamiya F104 Pro!-12-13_servo1.jpg   Tamiya F104 Pro!-12-13_servo2.jpg
rtypec is offline
Old 07-25-2011, 06:20 PM
  #5771
rtypec's Avatar
Default F104 X1 Build - Steps 14-15
I added a bunch of hopup goodies during the assembly of the upper deck.
Parts for step 14
Step 14 completed:
The aluminum body posts weigh a little more than the plastic ones, but these are pimp and are faster than the stock I swapped the titanium screw that holds the TRF415-7 antenna holder to an aluminum one...less weight and no stress on an antenna.
Parts for step 15
Not much to this step with four screws and two o-rings.
When attaching the upper deck to the chassis, make sure you use a flat surface to keep the chassis as flat and straight as possible while you tighten the screws.
Step 16 shows instuctions on attaching the R/C units to the chassis. Since I've already completed that step, this step no longer applies.
Steps 14-16 completed
It's starting to look like a car
Attached Thumbnails Tamiya F104 Pro!-14_parts.jpg   Tamiya F104 Pro!-14_complete.jpg   Tamiya F104 Pro!-16_parts.jpg   Tamiya F104 Pro!-15-16_complete.jpg
rtypec is offline
Old 07-25-2011, 06:25 PM
  #5772
rtypec's Avatar
Default F104 X1 Build - Step 17
Attaching the front upper arm is straight foward with no drama.
Parts for step 17
During initial assembly, it will be easier to screw the ball connector nut to the chassis before you attach the front upper arms.
Step 17 completed
Attached Thumbnails Tamiya F104 Pro!-17_parts.jpg   Tamiya F104 Pro!-17_complete.jpg
rtypec is offline
Old 07-25-2011, 06:28 PM
  #5773
Was wondering what you do to prevent the lower pod plate from cracking from the screw to the nut on that side?
bgrick is offline
Old 07-26-2011, 02:13 AM
  #5774
connyw's Avatar
Does anyone know where to buy different decals for F104Pro
connyw is offline
Old 07-26-2011, 06:12 AM
  #5775
lightfoot's Avatar
D-Drive in Japan is a great source for F1 decals... they are on vacation till August 8th....
http://d-drivesportsenglish.com/
