Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 07-23-2011, 08:28 PM
  #5746
Cool
hi rtypec, is the f104x1 comes with spur/pinion and silver can motor??
if no spur/pinion, what gear are you recommending for silver can on asphalt (rubber tires)?
thks
hansenhon is offline
Old 07-23-2011, 08:34 PM
  #5747
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by kb525
Anyone know where to get rubber tires in f104W sized rims? mp4/6 to be exact
Someone can correct me if I'm wrong here, but I believe the "W" wheels are F-103 wheels.
There are many types of tires for that.
http://www.tqrcracing.com/shop/produ...03&s_maker_id=
RedBullFiXX is offline
Old 07-23-2011, 09:54 PM
  #5748
rtypec's Avatar
thks
The kit comes with a 93T and 104T spur gear but no motor. For a track like Tamiya America, we usually use anywhere from 25-27T pinions.
rtypec is offline
Old 07-23-2011, 10:37 PM
  #5749
thanks a lot
looking forward to your next build
Old 07-23-2011, 10:45 PM
  #5750
Thanks man, i thought they were but wanted to double check. These foams wear down too fast for just bashing. I had to trim the front suspension to raise it up a bit as the added downforce would make the front drag at high speed.
kb525 is offline
Old 07-24-2011, 02:30 AM
  #5751
EEL Monster's Avatar
Has anyone tried the Ride rubber tyres?
Are the compounds comparable to the Tamiya rubber ie. is a soft Tamiya comparable to a soft Ride and so on?
EEL Monster is offline
Old 07-24-2011, 09:03 AM
  #5752
macavant's Avatar
Trader Rating: 65 (100%+)
I'm running the Ride wheels with Pit Shimizu med front and soft rears. The wear is good, rear traction is predictable but the car tends to understeer a bit in comparison to foams. If you're running your car on the street to bash - the rubbers are a good way to go.
macavant is offline
Old 07-24-2011, 10:59 AM
  #5753
Yea thats pretty much it. I race against some on road cars every so often. But still my fronts are halfway worn through rears have some life in them but i dont like how skitish they are sometimes. Not the most predictable tire.
kb525 is offline
Old 07-24-2011, 01:10 PM
  #5754
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Weight of stock hardware:
Weight of aluminum hardware:
Continuing with step 9, I used a dab of blue loctite on the steering horn assembly:
Step 9 completed:
Should've gotten the Fluorine Aluminum Hex balls (super smooth)! Blue kinda throws off the new colors but hey I love where you are going with the set up and im bout to enjoy my x1 just taking all the black aluminum off my All black edition f104 pro
54209 5x5mm
54208 5x8mm
hotdognobun is offline
Old 07-24-2011, 04:49 PM
  #5755
rtypec's Avatar
Default F104 X1 Build - Electronics Installation
I didn't get much accomplished with actually building the car today. However, I did work on the electronics.
Heatshrink and shoe goo hides most of the wiring mess:
Attached Thumbnails Tamiya F104 Pro!-electronics0.jpg   Tamiya F104 Pro!-electronics1.jpg
rtypec is offline
Old 07-24-2011, 05:16 PM
  #5756
[QUOTE=rtypec;9429430]Weight of stock hardware:
QUOTE]
As a total aside, what camera and lens are you using to take the photos - they are amazing?!
fritzzz is offline
Old 07-24-2011, 05:26 PM
  #5757
rtypec's Avatar
I'm using an old Canon Powershot SD550 set to macro on a tripod and a TON of photoshop
rtypec is offline
Old 07-24-2011, 07:26 PM
  #5758
rtypec's Avatar
Default F104 X1 Build -Carbon Fiber Prep
To continue with carbon fiber prep from one of my earlier posts, this is how the carbon fiber edges looked raw:
After wet sanding with 240 grit to remove sharp edges and application of two CA coats.
Not bad, but it can get way better.
Once the glue dried, I wet sanded the glued edges to smooth them out. I started with 400 and used finer grits until I got to 2000.
Pretty smooth...
Now it's time for the fun stuff.
Close up of the finished carbon fiber edge:
Apologies for the craptacular picture. It was impossibly hard to get the camera to focus because of reflections and highlights on the shiny edges.
Hopefully this gives you some into the process I use for prepping carbon fiber parts. It's time consuming but the results are awesome.
Attached Thumbnails Tamiya F104 Pro!-17_cf-prep1.jpg   Tamiya F104 Pro!-17_cf-prep2.jpg   Tamiya F104 Pro!-17_cf-prep3.jpg   Tamiya F104 Pro!-17_cf-prep4.jpg
rtypec is offline
Old 07-24-2011, 08:38 PM
  #5759
k_bojar's Avatar
Trader Rating: 30 (100%+)
Hey Rod - what kind of servo are you using? 9550/9551??
k_bojar is offline
Old 07-24-2011, 08:44 PM
  #5760
rtypec's Avatar
It's a 9550. I couldn't justify using one of my newer 9551s nor going out and buying a 9650 to evaluate. I'm trying to be a bit frugal with this build and only use stuff that I have laying around. The only things I've had to order so far are the screws and carbon shaft.
hotdognobun, did you say something? Your avatar has me hypnotized
I do have the low friction aluminum anodized hardware, but it's packed away and I quite honestly forgot that I had them...but to be a sport, I used an old worn out one for prepping the carbon fiber
rtypec is offline
