The Speed Passion Thread >
Like Tree57Likes
Old 08-15-2015 | 08:14 PM
  #12931
Slashracer1998's Avatar
Sorry if this was asked before but does anyone know if you can use a voltage booster to run 1s lipos on the Reventon S?
Slashracer1998 is offline
Old 08-15-2015 | 10:35 PM
  #12932
has been gone a few years from racing and wondering if this is a good combo to start with? Know that this is the old motor , but it worked very nicely when I raced with it before . Is it still competitive? Worth the combo price?
http://www.rcmart.com/reventon-brush...Path=1100_1252
Tnx
//Marcus
MarcusEngdahl is offline
Old 08-19-2015 | 11:34 AM
  #12933
Tnx
//Marcus
Anyone?
Old 08-19-2015 | 12:58 PM
  #12934
qcrc's Avatar
Tnx
//Marcus
Yes it is still competitive. Here is a better place and better price.
http://shop.speedpowerrc.com/revento...on-v3-0-combo/
qcrc is offline
Old 08-19-2015 | 01:12 PM
  #12935
Tnx! is it big difference between reventon pro 1.1 and reventon R? pros and cons?
Old 08-19-2015 | 01:22 PM
  #12936
daveaustin5's Avatar
That's a different speed controller.
I've purchased $1000's of dollars worth of stuff from RCMart and not had a single issue with them.
I've had both. I found the 1.1 to be much smoother.
daveaustin5 is offline
Old 08-19-2015 | 02:00 PM
  #12937
Tnx!
Old 08-19-2015 | 02:39 PM
  #12938
tbrymer's Avatar
Tnx!
1.1 is super smooth and rcmart is great!
tbrymer is offline
Old 08-29-2015 | 01:16 AM
  #12939
Coopz's Avatar
Can anyone give me some hints to squeeze more power out of my SP 21.5 and Reventon R. I'm running it in blinky touring cars with a very similar fdr as the other cars but it just lacks power and brakes. I've tried maximum timing but it's still getting overtaken on the straight and the same cars also have more punch out of the slow corners. It's brakes are also terrible. Have to brake a lot earlier for the corners and even then it just stops gently. Braking is set to 100%. Another guy at the club said SP brakes are rubbish and he switched brands because of it. Am I doing something wrong? I'm in the blinky class as the racing is supposed to be even but I see to be at a disadvantage.
Coopz is offline
Old 08-29-2015 | 04:31 AM
  #12940
rtenzo02's Avatar
Brakes on my reventon work great , I would try to recalibrate your transmitter to the esc after changing its settings, Ive never used a SP motor , sorry.
rtenzo02 is offline
Old 08-29-2015 | 08:04 AM
  #12941
tbrymer's Avatar
Brakes on my reventon pro 1.1 work great. DR on my brakes are at 58%, with a 17.5T D4 motor (12.5 rotor), and it stops quickly.
tbrymer is offline
Old 09-02-2015 | 09:45 AM
  #12942
eR1c's Avatar
Put a +40 sensor unit in my SP motor ..WOW, -my motor really came to life. Glad I asked about the sensor units, ..had I not I would have been really disappointed w/ what seemed like an anemic motor.
eR1c is offline
Old 09-02-2015 | 05:43 PM
  #12943
Tc460mph's Avatar
+40 is timing right? What cells are you running?
Tc460mph is offline
Old 09-02-2015 | 06:04 PM
  #12944
eR1c's Avatar
Yes,the 40+ timing is a sensor unit made by SP.
This is a 21.5t motor, the "MMM" series. I am running a 2 cell shorty pack, 100c 4600 mah in a tamiya m05v2. The esc is a SP, its the stock club esc.
eR1c is offline
Old 09-03-2015 | 01:47 AM
  #12945
Tc460mph's Avatar
I don't think I can add any timing right now because my motor gets up to around 160 degrees and I'm running a 4s 2700mah.
Tc460mph is offline
