The Speed Passion Thread
Hello. Is there type of rebuild kit for the N2159 motor? I took mine apart and cleaned it with brake cleaner. Also, can these be used for off-road. The ESC is a reventon. Also, is there a way to program these without a program box? My esc is sensored but I don't have the sensor cable. Can this setup still be used sensorless? If so do I have program it to be sensorless or will the esc know to automatically be sensorless if it doesn't sense the cable present? Thanks
Tried to run my 13.5 speed passion system in mod 1/10 latemodel class and I was getting lapped.
Probably going to run it in my TC4 touring car when I get it.
It was a ready to run system with forward only with brake.
It came outa my Durango DEX 210.
It think it will be perfect in a touring car.
But its not fast enough for anything else I have.
Suspended
Is it still a better idea to use the Muchmore software to Program the Speed Passion Reventon Pro or has SP updated their software to eliminate the need
Thanks. Is there. What's the best way to clean the motor? Also can ESC be programmed without software? I'm using combo sensorless setup.
i updated all my speedpassion esc's to the latest software above.
ALL now have a very minimal cogg. 2x revention pros 1.1
2x revention r
it would not be an issue for most but i run F-1
and is a very light car and I am Veeerrryyy picky
I will dump the whole lot for 65 shipped if anyone interested.
1 revention r is brand new 1 pro 1.1 is also new.
If you can find the old version of the software v21 which is what I had loaded on all they will work perfect. I unstalled the old version v21 b4 installing the new and that killed me as i could not revert
i had to remove the v21 b4 installing the new spftware
Sold them all...hope he can find v21
2x revention r
it would not be an issue for most but i run F-1 and is a very light car and I am Veeerrryyy picky
2x revention r
2x revention r
57Likes
