The Speed Passion Thread
The batteries are still suspect. I doubt both ESC developed the problem at the same time. You have gotten a batch of defective batteries. I would test the IR of both packs.
If both ESC's are new, then maybe the default voltage cutoff is set too low. Try turning it off. Ask someone else to try running one of your batteries if it turns out not to be the voltage cutoff.
Okay guys i'm having a Speed Passion issue with both my touring sedans.
17.5 Orion vst2 pro on a SP Reventon Pro
21.5 Novak Ballistic on a SP Reventon Pro 1.1
Both have Peak 90c 5000mah lipo batteries
my problem is identical on both sedans
when at dead stop and punch throttle of take off really slow both speedo's cog/stutter pretty bad.
I just put new sensor wires on both cars with no change at all.
Any suggestions ?
Any suggestions ?
R/C Tech Elite Member
Sensor cable perhaps?
didn't ry the novak motor but did play around with the orion motor car and went from +10 degree of timing to 0 then to -10 degrees of timing with no difference what so ever.
Do anyone how to get the software? Trying to change the firmware but I can't the app for the module and the site is having issues uploading.
V4 17.5 motor
It's time for a new 17.5 motor. Has anyone tried the new v4? I would like some feedback regarding performance and how it compares to others like orca, trinity etc. thanks.
thinking of getting the reventon pro for 1s and 2s...can it handle 4pole motors
I'm curious as well, need a motor for 12th scale.
@astgerma, I can tell you this much, I'm running a v4 8.5 in 2wd buggy and its super smooth and lots of power.
the manual hasn't been updated since 2013
Need help
Esc Reventon pro 1.1. Software stock01 v22.
Problem come when i pull throttle they have little kicking start on low rpm .. after that it normal on higher RPM this happern when i set " DRRS = 5 ".. so every i off throttle and pull back it will kicking & than normal to higher rpm. problem on dead band or natural range area.
But
If i set " DRRS = 3 or 2 or 1 " this not happen .. alll throttle smooth.
* Already change sensore wire ... battery .. & power cap .. still same problem ..
But
Increase dead band setting to 6 degrees . recalibrate esc and transmitter.
still same problem .. cannot use ddrs 5 and above ... throttle still have one time kicking on start ..
