The Speed Passion Thread
My speed passion MMM 21.5 armature has a lot of side to side movement. Is this normal?
Compared to other motors I have, they only have a "tick" of movement..
Hello Sean,
Please forward any info or email to [email protected], and we will direct you to our Asia division for service.
Thank you
SP USA
Thank you
SP USA
hopefully this gets me some where
When will speed passion be releasing the LMP bodies? I heard that there is a possibility it will be released in oct.
hello i have problem;
i have reventon - r esc i wanted to upgrade firmware i pluged esc to pc everything was ok then i selected drift program it was loading but it stucked at %21 thats why i closed program and esc dont work anymore leds not working and i cannot program and pc cannot see esc what should i do ? please help..
regards..
regards..
Hi everyone,
I tried to put MuchMore soft in my Speed Passion Reventon Pro and it seems to work properly. But my LCD Program Card can't be used with MuchMore softs (any items can be read).
How do you do guys to upgrade your SP LCD Program Card with the Muchmore one?
And how do you do to put back SP softs in the esc after having put MuchMore one?
Thanks for help,
G-rem
Thanks for help,
G-rem
I just purchased the reventon pro (not the 1.1 version) in a combo deal with a 8.5T V3 motor. Is the reventon a good esc for switching between modified and blinky stock software?
Yes. I've been running the same Reventon Pro for a year now in everything from 17.5 blinky to 4.0 boosted. As long as you properly download and install the software, you can literally switch software profiles in the time it takes to boot up the computer and make about 5 mouseclicks.
I look forward to test the esc with the 8.5t motor and with some stock motors.
guys will someone help me ? i have reventon r esc leds not working and pc and program card does not work is it trash or can i save my esc ?
Wiring diagram- between Motor Sensor wire and Smart LCD Program Box
I have a short course truck with the esc/receiver wire difficult to access.
One of the team drivers told me instead of unplugging the receiver wire from the esc, then plugging a wire between the esc receiver pins and the smart lcd program box, you can connect the Smart LCD Program box to the wire that plugs into the Motor Sensor port.
The 'pro' gave me a cable he uses that fits the motor sensor cable and the lcd program box, but its not working.
I have tried it on a GT2.0 and a Pro esc.
Is this possible with a SP ESC or is this possible with other brands only?
Does anyone have a wiring diagram to confirm my cable is wired correctly?
Fred
Fred
Best rotor for 17.5MMM
I'm thinking of upgrading the rotor for my 17.5MMM but I'm not sure which one to get. Is there a rotor that will give more torque/power and speed?
Bigger rotor give to you more torque, but it also increase motor temp.
regards..
regards..
Hello,
Restart your computer and make sure no other program is running. Start interface program and plug in the program card with the ESC. Click 'S' on the keyboard to enter safe mode and process to Firmware recover update.
SP CS
SP CS
regards..
regards..
