The Speed Passion Thread
Tech Legend
for the current 21.5T motors available from Speed Passion, I have a question concerning 2S usage.
I have heard that the 21.5T 1 Cell version is a newer build than the V3.0 Competition and is usable on 2S. Basically it was the basis for the MMM, at least so I was told. I would like to know for USGT touring usage, is this motor viable?
Thinking of picking either that one up or the V3.0 Competition 21.5 .
Tech Legend
Why doesn't my esc work?
Hi guys,
Got myself a new Reventon R ESC & 21.5 mmm motor for my tamiya F104. It all looked good in the box - and that's where it ends.
I have bench connected all the components together to battery, rx, etc including a savox servo. I have tried to get the components working but nothing! The battery is charged but no lights come on or anything. Tried just the ESC by itself but still no life. I am new to RC and I thought the electrical setup would be simple. I seem to be wrong there! Any ideas for what I have done wrong / or need to do?
Cain, I am running the 21.5 1 cell in my F1 car on 2s and it flies. I've always liked the 1s motors over the 3.0 or even the MMM. Sadly the sources for them are drying up so I'll be moving to other motors at some point in the near future.
Hi guys,
Tech Legend
Thanks for the info!
Picked up some 25.5's as they run in the region ROAR style VTA from what I have been told basically.
May pick up a 21.5 though if I can fine one for a good price + shipping too.
V3 then 1S V3 then MMM V3.....however, 1S 21.5 is discontinued.
Hi guys,
Also, make sure your signal wire going from the receiver to the ESC are correct....
Hi guys,
Check that from reciever to speedo the polarities are correct.
Tech Legend
Thanks for the info Solara!
When you say NO LIFE.....you mean, no servo movement? no lights on the ESC, no motor movement no nothing...? If so....I don't think you have any power going thru the ESC....see you can bring it to the local hobby shop and ask for help, or, shoot a video and post here and we might be able to help you in some form....
On the Reventon R ESC - where are the lights located? In the switch I assume.
21.5 MMM gets too hot in less than a minute
I was testing my car by driving it around on the floor inside my house. I was just slowly driving it up and down my hallway to see if everything was working fine. When I picked it up and touched the motor I noticed it was pretty warm for only 1 or 2 minutes of slow driving inside the house. I took the motor off the car and ran it for about 40 seconds for full throttle and I could slowly hear it get bit slower as the temperature went up to around 115-140°F depending on where on the motor I was measuring from. I'm thinking this is not normal because my 17.5 MMM only gets slightly warm when I do the same thing. I took the motor apart and I could not find anything wrong so what would cause the motor to get hot so quick?
@ Gemec
The light is located in the side of the ESC in the groove.
Try calibrating the ESC to your Tx sometimes you have to reverse the throttle signal for it to work at all.
Follow manual for Calibration
Tech Legend
As for your temp issue, do you notice any funny with the motor on starts, stops, etc?
Tech Legend
As for your temp issue, do you notice any funny with the motor on starts, stops, etc other than the temp.
