The Speed Passion Thread >
Like Tree57Likes
Old 11-30-2012, 08:21 PM
  #10801
askbob's Avatar
Trader Rating: 29 (100%+)
What is the lowest turn motor the Revention S will be OK with in a 2wd buggy?
askbob is offline
Old 11-30-2012, 09:56 PM
  #10802
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Originally Posted by bigwavedave33
What about in a heavier 4x4? SC10 is pretty light comparably to the SCTE I guess I should have mentioned chassis and weight? I thought it would be ok though.
I got my SC10 4x4 porky with the exotek chassis to give it the weight it needs to hang with the losi's when it gets bumped lol.
Temps on the ESC were about 100 degrees if that. Probably benefits a lot that the fan stays on.
Cain is offline
Old 12-01-2012, 01:22 AM
  #10803
Originally Posted by Solara
Stock1 (boost/turbo) with 4.5....we have setup on our website for you to try. Use it...that is the fastest setup so far.
I can't open the files .
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Akita is offline
Old 12-02-2012, 03:49 PM
  #10804
Tech Legend
Cain's Avatar
What FDR do people recommend for:
- 17.5 Blinky Touring 7.4V
- Using V3.0 Competition motor with the 20 degree green timing board
- Carpet Track, Rubber Tires
- 50 x 50 track size max
I was thinking starting at 5.0 FDR and working from there?
Cain is offline
Old 12-02-2012, 04:07 PM
  #10805
Tech Legend
Trader Rating: 1212 (100%+)
You'll get passed @5 I'm running 96/41*1.95=4.74 17.5 boosted A LOT with MMM V3 17.5 and GT Pro. Motor coming off at 140. If its really tight you might want to run a little higher to increase corner to corner speeds... That is assuming you are going to be running SP motor. In a non boosted class a reedy sonic, duo3.5 or revtech might be a better choice... They are higher KV.
bigwavedave33 is offline
Old 12-02-2012, 04:44 PM
  #10806
quickershifter's Avatar
Hi guys, new to TC. Just bought new Rev PRO esc. Combo with Yeah Racing HACKMOTO 13.5T. Timing set at 15°. FDR 5.85. What setup should I run? Track asphalt, medium, temp around 28° to 33°.
Thanks in advance.
quickershifter is offline
Old 12-02-2012, 06:38 PM
  #10807
Tech Legend
Cain's Avatar
Thanks for the info!
Cain is offline
Old 12-03-2012, 06:02 AM
  #10808
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Green board in the middle geared at a 3.6 or so will be plenty fast
Marcos.J is offline
Old 12-03-2012, 07:31 AM
  #10809
Trader Rating: 17 (100%+)
GT 2.0 pro question: Could a GT 2.0 Pro handle a 4 pole 4000kv motor of would I see a nice fire???
It will work perfectly with 4 pole motors on GT2 PRO and it works on the heaviest SCT like the LOSI SCTE....already been using that for almost a year. No problem...
Solara is offline
Old 12-03-2012, 07:33 AM
  #10810
Please check again....updating server and it should work now.
Solara is offline
Old 12-03-2012, 07:47 AM
  #10811
Originally Posted by joech
Does the GT2 has DDRS in blinky mode?
Thanks.
Not sure if this was answer, but do you mean the GT 2.0 ESC? If so, yes you can adjust DRRS.
SP Tech is offline
Old 12-03-2012, 08:05 AM
  #10812
Originally Posted by ysyracing
Hello,
How many internal timing degrees have each motors?
1C105V3 Competition V3.0 1 Cell Motor - 10.5R
138105V3 Competition V3.0 Brushless Motor - 10.5R
SP000037 1/10 Competition MMM series 10.5R Brushless Motor
Regards,
JoseLu
I think your question should be asking about the BUILT IN TIMING from these motor...all of the SP motor are running abotu 12-15* built in timing...plus the sensor board timing goes from 0-50. Plus your ESC software if you are running timing software.
Hello,
Thanks for your reply.
I would like that you confirm the information.
If I add the internal and external timing I will have the following timing, per motors with their original unit sensor.
1C105V3 Competition V3.0 1 Cell Motor - 10.5R. 12-15º minimum and 22-25º maximun.
138105V3 Competition V3.0 Brushless Motor - 10.5R. 12-15º minimum and 22-25º maximun.
SP000037 1/10 Competition MMM series 10.5R Brushless Motor. 23-26º minimum and 32-35º maximun.
Is that correct? Thanks.
Regards,
JoseLu
ysyracing is offline
Old 12-03-2012, 08:09 AM
  #10813
Tech Legend
Cain's Avatar
I had the green board full left (so 20 degree or "0" as the can shows) and with FDRs ranging from 4.2 to 3.6 the motor faded about 3 minutes in to practice runs.
I am going to try a higher FDR and see if that helps. We starting out though, very fast, good torque considering its the 12.3 rotor.
Cain is offline
Old 12-03-2012, 08:39 AM
  #10814
I was using green board full timing to the right and gear 4.5 and higher (4.6..). The new thing we are trying is the super7 12.5mm rotor...in 21.5 GT class, it is MONEY in the carpet, don't know about 17.5....
Solara is offline
Old 12-03-2012, 08:58 AM
  #10815
Tech Legend
Cain's Avatar
Cain is offline
