The Speed Passion Thread >
Like Tree57Likes
Old 10-21-2012 | 07:27 AM
  #10381
Marcos.J's Avatar
Super Moderator
Originally Posted by RSCosworth
V19?
Yes it's for 10.5 and slower motors , don't know if is the final version but is working so far
Marcos.J is offline
Old 10-21-2012 | 08:12 AM
  #10382
Is it availible to download yet or is it still in the testing phase?
RSCosworth is offline
Old 10-21-2012 | 08:24 AM
  #10383
Mark Erce's Avatar
Default reventon for 1s 12th scale racing 13.5 blinky
Q:
1. which reventon esc supports 1s lipo(no rx booster needed)?
2. if I get the reventon stock club or reventon s will i need a rx booster?
thanks again Speed Passion USA
Mark Erce is offline
Old 10-21-2012 | 08:26 AM
  #10384
Marcos.J's Avatar
Super Moderator
not yet Solara will know more when it will be available
Marcos.J is offline
Old 10-21-2012 | 09:28 AM
  #10385
mtbboy's Avatar
Just got the reventon r.
Trying to use the pc interface however after plugging everything in it is just sitting on the opening window "please connect esc".
What am I missing?
I held down the value button upon plugging in as well.
D.
mtbboy is offline
Old 10-21-2012 | 11:31 AM
  #10386
Timbo99's Avatar
What am I missing?
D.
Hi,just go to the speedpassion website and checkout the installation video.
If your trying to do this with a mac,you need to run the drivers on a windows pc.
Hope this helps.
"let's go rangers" Messier,Richter,Gretzky,ahhhh them were the days!
Timbo99 is offline
Old 10-21-2012 | 12:21 PM
  #10387
[QUOTE=Radio Active;11338588]I'm trying to find the sweet spot for a Speed Passion 1 cell 10.5 in blinky 12th.
Originally Posted by Timbo99
Hey,this goes out to Howard and the SP Techs,as we have our national titles next weekend,has this Reventon Pro AND the software been approved yet?
Just wondering..........
Need to know V.Soon guys,
Thanks in advance,
Tim
We can inquired during the week. Unfortunate Wendi not control the approval time.
Originally Posted by zzztech
Does the MMM motor come with 12.5mm or 12.3mm rotor for stock and 21.5?
what about the V3 (non MMM)
The 12.5 rotors are optional.
Originally Posted by Eric Summers
Anyone using the Reventon with a Thunder Power motor?
ems
I have seen them run with zero problems at the track.
Originally Posted by Mark Erce
Q:
The 1s version of the Revention is not yet released.
What am I missing?
D.
Is your fan unplugged from the ESC when doing this process? That may be causing your reading problems.
SP Tech is offline
Old 10-21-2012 | 01:59 PM
  #10388
skypilot's Avatar
any SP drivers coming to the Timezone GP next month??
skypilot is offline
Old 10-21-2012 | 04:32 PM
  #10389
waggaclint's Avatar
Hi guys i was wondering what the Cirtix D-Manager Combo Sets are like, are ther reliable etc? do they have many problems? I was looking to run one im my HPI Drift car..
waggaclint is offline
Old 10-21-2012 | 05:48 PM
  #10390
Timbo99's Avatar
Default Not Approved Yet
Originally Posted by bigtez
Would that big race be the Nats at Logan Poop?
I am in a similar situation. I have entered stock, but won't be able to race if the boosted 13.5-21.5 software isn't out in time.
Check the above post,think it will be a bit risky as you guys may be using hardware and software that isn't roar approved yet,and may result in a DQ.......hope it gets the nod before at least Friday for you.
Timbo99 is offline
Old 10-21-2012 | 06:16 PM
  #10391
bigtez's Avatar
I had a brief read of the AARCMCC rules last night and didn't see any mention of ROAR approval being required for speedies. As timing/boost are open in stock and mod I don't think they would require approval.I will certainly be having a good look at the rules when I get a chance.
bigtez is offline
Old 10-21-2012 | 11:29 PM
  #10392
hey guys any help here
Ive got the reventon pro and it worked fine until i went to adjust settings using my iphone and now the esc wont work at all
dan200487 is offline
Old 10-21-2012 | 11:35 PM
  #10393
huaicin's Avatar
I have SpeedPassion 1/10 Competition MMM series 10.5R Brushless Motor and Reventon R ESC.
My car just doesn't seems to brake when I push the trigger all the way out. When the trigger is on neutral zone, my car seems to brake just a bit. Is the brake function when the trigger on neutral position or when we push the trigger? I've calibrate the ESC with my transmitter on REV, try different running mode, but still I can't apply brake on my car.
I've read on a couple post but I can't find a solution. Sorry if it's discussed before.
huaicin is offline
Old 10-22-2012 | 03:33 AM
  #10394
Marcos.J's Avatar
Super Moderator
check your brake force with the LCD box
Marcos.J is offline
Old 10-22-2012 | 04:05 AM
  #10395
Yes my set up is posted a page back or so
Been testing the v19 with a sp10.5 and is ballistic feels like my 4.5 in blinky mode. Smooth power not alot of wheel spin. So far at a medium asphalt track with 100% boost fdr at 5.10. Temps after 6 minutes about 136 degrees.
cheers Marcos. can i trouble you to post it again please? I've went back 20+ pages and couldnt find it
poop is offline
