The Speed Passion Thread
#7502
http://www.speedpassion.net/us/produ...SP000037&c=MTR
#7504
solara, i am abit confused here. i just check speedpassion and it show the new mmm motor come with green +20 sensor in pic and end bell said +20 as well.
The sensor that came with the MMM (all of the MMM motors) are the RED 11-20* sensor, NOT the green 21-30* sensor. Green one will be optional.
Then end bell reading = 11* to 20*...positive 20°, not 20° or more. But of course, once you add the GREEN one in there, the read is not longer apply, but you should be able to figure out it will be 21° to 30° as max (full right).
The picture only showing that as option....I will have them to add that line on it.
#7505
thanks for the quick answer solara
#7507
I will have the web master to fix that...
#7508
So I ordered a GT 2.0 from the website and the paypal payment went through on the 15th. But on the website my order is still pending, anyone else have that problem? All the parts that I ordered are still in stock on the website.
Edit: nvrmnd i just got an email from king golden saying it shipped and will be here tomorrow lol. That makes little gearhead so happy
#7510
i have a question, in some set up i see that they are selecting custom boost settings to 36 degrees , i was going to set mine the same i have the down loaded the latest but i am using the hobby wing programme card is the reason why i can not select custom settings ?
#7512
well i run Mod. there are settings in stock which im not sure of. but i need to know what they do. more like the Boost AC, like less RPM means faster, or more RPM means faster ? and does this work in with the Boost start RPM setting ? Mod is simple, easy to work out, ahaha and is fast.
#7514
So the lower you set ACC, the faster the ESC will add an additional step in boost timing to the motor, which means faster acceleration, but more heat.
Yes, it works together with boost start RPM.
