The Speed Passion Thread
#136
When that happened to me it was usually a motor with a faulty sensor board or a bad cable, the speedo will try to start in sensored, but struggle, then it switches to sensor less and works properly. Usually a different motor (or cable) will solve the issue.
I have also seen this happen on 4 cell with the drrs set too highly, but its very rare.
i'm running 13.5 touring...what drrs setting would you recommend?
thanks
#137
R/C Tech Elite Member
Well if you wanna stick to a 5.5 I would say the GT 2.0 LPF and the 5.5, part #'s
spext98802lpf
sp13855
spext98802lpf
sp13855
So Adam:
First time on this thread....If I was looking for a Speed Passion ESC and motor for my 1/10 J Concepts 4WD buggy on fairly large tracks ( 130'straights) using SMC 4900 Lipo saddle packs. Which SP system or ESC and motor should I get. They must be Roar approved. I'm also looking at the Tekin RS Pro 5.5 system. If you can help me it would be greatly appreciated. If you wish you can email me at [email protected] with this info.
thanks....Don
thanks....Don
#138
Hi there, does anyone know where I can get a new sensor unit (SPSB168) for my 13.5 .I took a hit and it broke me sensor unit.Have been looking on the net but have'nt found anything.Would prefer to be able to get one from the USA (I live in New Zealand).Any help would be much appreciated , thanks.
P.S. IS it possible I can get one from Schumacher USA.
#140
Anybody have one of the 8th scale ESC?? we are converting an 8th scale onroad to electric, and now our on our 3rd speedo. the first two have smoled after a couple minutes. "ESC temp went to like 140 plus and started to smoke. we rare unning the 5.5 T with 14.4v volts. finally got the last one to run for a bit but the caps on the side are still getting to 140 pkus. all other parts of the speedo are cool like 100 ,and the motor is only 110 120. the gearing is close and the car rools freely. just not sure the SP ESC is up to the advertised 14.4v with thier 4.5t motor.
we are at the lowest punch. the ESC timing all the way down to setting 2, no drag brake
the thing is insance and easily as fast as an 8th scale nitro.
Thanks.
Thanks.
#141
#142
Competition 2 motors
What type of rotor does it come with? Sintered or bonded? I m interested in that 3.5t and want to know the kv rating or watt rating of it.
#143
Give me a call or email
#144
Give Shawn a call on Tuesday at the shop
Thanks.
Thanks.
#145
Just got myself a speed passion LPF v2 and 10.5 this week and ran it for the first time today. Having an issue with it stalling under heavy acceleration. Tried all sorts of gearing and settings on the ESC and still having issues. Unplugged the sensor plug at home and running it around the kitchen its a bit better.
Anyone got any ideas?
Cheers
Keiran
Cheers
Keiran
#146
Can anyone give me some suggestions. Thx
I just installed new ESC (SP GT2 Pro carbon edition) on T2009 xray. I intended to use LRP brushless motor (3.5 turn with 13mm sintered). and running Lipo 7.4v 5000nimh 30c.
My questions.
1. what is the best FDR (ratio) should I run?
2. What is the max temp of my motor and esc should I run for safety?
3. Can i measure torque using SP brushless analysis tool
My questions.
#148
with the SP GT2 Pro carbon edition do you have to turn the temp cut off option off when running a 3.5 or 4.5 and i also would like to know a good starting point for 3.5 and 4.5 fdr. thanks
#149
Super Moderator
Dont need to turn off the temp cut off with the GT2.0. For the 3.5 and the 4.5 I would start with DRRS #4-#5 and with about #3 for timing ( 7.5 degrees) FDR for the 4.5 around 8.5 to 8.75 depending on track and for the 3.5 between 9.75 to 10.25 also depending on the track.
#150
Super Moderator
My questions.
My questions.
Motor temps I would keep them under 165
