The Speed Passion Thread >
Like Tree57Likes
Old 04-21-2009, 12:08 AM
  #121
smilekt's Avatar
Originally Posted by dbmartin
Happy to report that I ran my new 2.0 GT this weekend with no thermal issues. Ran both a 3.5 and 4.5. The speedo never got hot for me, The 3.5 temped at 178 degrees F which was a little hot, But I think if I work on the setting a little, I can bring this down.
what setting profile u use ?
smilekt is offline
Old 04-21-2009, 07:08 PM
  #122
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by smilekt
nice nice .. do more report about GT 2.0 ..
settings on ESC
1. - 1
2. - 1
3. - 4
4. - 6
5. - 4
6. - 1
7. - 2
8. - 2
9. - 6
10.-1
ESC temps stayed around 90 degees all day. motor temps never got over 110. even though its safe to do, i don't like to run my motors hot. especially mod motors, if i need more power i will change motors, on this day, with low traction, a 6.5 was plenty. actually ran right with the 4.0's and 4.5's on the track.
skypilot is offline
Old 04-22-2009, 07:57 AM
  #123
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by skypilot
settings on ESC
1. - 1
2. - 1
3. - 4
4. - 6
5. - 4
6. - 1
7. - 2
8. - 2
9. - 6
10.-1
What FDR were you using with the 6.5 ?
Marcos.J is offline
Old 04-22-2009, 09:20 AM
  #124
skypilot's Avatar
89/24 on a Mi3 whatever that is
skypilot is offline
Old 04-22-2009, 09:21 AM
  #125
Super Moderator
Marcos.J's Avatar
6.67 fdr got it thanks
Marcos.J is offline
Old 04-22-2009, 04:18 PM
  #126
quantum's Avatar
anyone?? bueller?...
Originally Posted by quantum
i am using the GT v1, and i am experiencing a problem, where if i ever tap the brakes, the car hesitates for moment before it gets moving again. i mean i am just tapping the brakes and then getting right back on the throttle and i lose time waiting for it to get moving again. any idea what could be wrong?
here are my settings:
1) 1
2) 1
3) 4
4) 6
5) 3
6) 1
7) 1
8 ) 1
9) 5
10) 1
quantum is offline
Old 04-22-2009, 04:38 PM
  #127
skypilot's Avatar
i wish i could help, i had that issue when the esc first came out and can't remember for the life of me what the problem was, it is fixable so don't give up hope. maybe it was a cap issue.
skypilot is offline
Old 04-22-2009, 05:32 PM
  #128
Default GT 2.0 PRO Advise
I have just bought the GT 2 Pro and will be using it for the 1st time this weekend. Firstly when I set it to my transmitter can I use the setting box to programme it for the 1st time or do I need to use the little button on the esc.
Also I will be running a speedpassion 13.5 and racing on a large open track on asphalt using rubber tyres, could the speed passion guys give me a good starting point set up for brakes, timing, gearing etc.
Many thanks
FLAT OUT is offline
Old 04-22-2009, 07:08 PM
  #129
killingtime's Avatar
Originally Posted by killingtime
I'm running the older SP esc, the ver 1.0. My question/problem is that I only get about 10% power off the line and then 1/2 sec. later full power. BTW, my radio is a Helios with Spektrum.
Thanks for any help you can provide
I remember seeing this discussed/resolved in the old thread but.....
For some reason I was thinking it was a throttle setting on the Helios that was the culprit, but I've tried all kinds of variations and still having the same issue. I wish someone form Speed Passion could chime in on this one. I can only imagine that they have dealt with this issue more than once.
anyone?
killingtime is offline
Old 04-22-2009, 09:05 PM
  #130
Mike Haynes's Avatar
When that happened to me it was usually a motor with a faulty sensor board or a bad cable, the speedo will try to start in sensored, but struggle, then it switches to sensor less and works properly. Usually a different motor (or cable) will solve the issue.
I have also seen this happen on 4 cell with the drrs set too highly, but its very rare.
Mike Haynes is offline
Old 04-23-2009, 05:04 AM
  #131
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
As it shows in the manual (which I highly advise you read), you still need to calibrate the radio to the ESC like all other ESC's on the market, that has not and will not change. Once that 10 second operation is finished all setting are changed from the program box
Many thanks
I have already emailed you with more specific questions to your application, please check your junk mail box or email me @ [email protected] with more specific details of which radio, motor, servo, batteries, gear ratio your running.
anyone?
abailey21 is offline
Old 04-23-2009, 01:14 PM
  #132
Thanks Adam
Unless you were also trying to sell me replica watches, viagra or weight loss pills.... I didn't get your email I've sent the requested info to you.
Old 04-23-2009, 01:18 PM
  #133
abailey21's Avatar
I was the pill for E.D.
I'll be looking for the email lol
Thanks Adam
Old 04-23-2009, 04:25 PM
  #134
skypilot's Avatar
thanks adam, package arrived yesterday, new shirts are cool
skypilot is offline
Old 04-23-2009, 10:08 PM
  #135
Trader Rating: 15 (100%+)
So Adam:
First time on this thread....If I was looking for a Speed Passion ESC and motor for my 1/10 J Concepts 4WD buggy on fairly large tracks ( 130'straights) using SMC 4900 Lipo saddle packs. Which SP system or ESC and motor should I get. They must be Roar approved. I'm also looking at the Tekin RS Pro 5.5 system. If you can help me it would be greatly appreciated. If you wish you can email me at [email protected] with this info.
thanks....Don
7.5man is offline
