T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 07-18-2011, 09:18 AM
  #7951
Trader Rating: 17 (100%+)
Originally Posted by OVA
Thanks...I have the Exotek chassis..and it is alittle thinner than EJ by .25mm
Hey Ova I have an "Ej" chassis sitting in my pit bag. It would like to compare it to the Exotek this weekend if possible. Not sure If I can make the race but I will be there for at least one day. (I hope)
Mr.A Morris is offline
Old 07-18-2011, 10:00 AM
  #7952
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
ygpm
OVA is offline
Old 07-18-2011, 01:16 PM
  #7953
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Fyi - TOP Racing USA now has Photon kits back in stock... so other US retailers, like amain, etc should also have stock soon..
hanulec is offline
Old 07-18-2011, 05:30 PM
  #7954
odpurple's Avatar
Thanks, Mike
Like the man said, Photon kits are back in stock.
We also now have the Rebel 10 pan car kits and all the new pan car option parts: Option motor plate sets, Alloy 'A' Bearing Carriers, Threaded Front Axles and Alloy Servo mounts. And people will be lining up for these: Alloy Steering Blocks for the Sabre FD!
odpurple is offline
Old 07-18-2011, 05:57 PM
  #7955
hanulec's Avatar
if anyone is looking to come to the ROAR Paved On-Road Nationals at Jackson RC, we really have our Photon's dialed on this track. you now have the opportunity to buy a new kit and join in on the fun. locally there are usually 4-5 Photons putting it into the a-main w/in 17.5 TC, and two to three in 13.5T (and/or modified) each week.
if anyone wants to make some moves right before the race please post online here... we will get you pointed in the right direction.
-mike
hanulec is offline
Old 07-18-2011, 06:18 PM
  #7956
Jerry P's Avatar
Trader Rating: 44 (100%+)
-mike
Jerry P is offline
Old 07-18-2011, 06:44 PM
  #7957
hanulec's Avatar
Thanks to everyone who PM'd me -- but I'm putting this Jackson setup discussion in the open forum. You need the following:
- Base setup: http://racerlog.com/w/images/3/39/Ho...up_11-6-10.pdf
- Replace the front springs w/ 367s
- Make sure to have Side Piece Racing Mira Outdrives & XRay 50mm ECS
- Run a Spec-R or Yokomo 40t gear diff in the rear - 30wt or lighter shock oil filled to the top
- You must build you shocks correctly - http://racerlog.com/wiki/T.O.P._Photon#Shocks
- If you're running 17.5 or 13.5 you're going to need a fast, high cfm, high amp draw fan on your motor. Unfortunately I don't have any Geish fans to help you guys out... so please look around.
- Small spurs for 17.5 and 13.5T - 80 to 86t; Big spurs for modified - 108t (but not larger.. they will hit the curbs)
- Tire sauce: Tweak (warmers are not necessary...)
I will not be at Jackson this weekend, but Larry and Jerry P will be in the house. Don't be afraid to ask questions. Jerry P and I will be at the Nats Wednesday night during the pit setup. Larry and EJ will show up Thursday morning. I hope to see you guys all in attendance.
hanulec is offline
Old 07-19-2011, 01:13 AM
  #7958
bigbank66's Avatar
Hanulec....im running 17.5 ramping on a big pavement track..about 160ft straight...i need a good tekin set-up...i need straight speed...cars her r really fast...i also need a good fdr for the car also...thanks for all your help....
bigbank66 is offline
Old 07-19-2011, 03:39 AM
  #7959
hanulec's Avatar
I haven't run 17.5 ramping outdoors. What motor are you running. I'd expect an indoor setup with more gear would work. But the motor is very important...
hanulec is offline
Old 07-19-2011, 01:07 PM
  #7960
bigbank66's Avatar
D3 trinity duo
Old 07-19-2011, 02:04 PM
  #7961
hanulec's Avatar
D3 trinity duo
2nd to last timing mark on the motor.
100t spur (pinion to goto FDR of 5.3)
50 Turbo / 10 boost
5k start / 13k end
tp5
hanulec is offline
Old 07-19-2011, 05:39 PM
  #7962
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by odpurple
Thanks, Mike
About when will the Rebel 10SS become available?
ewashburnaf is offline
Old 07-19-2011, 06:32 PM
  #7963
odpurple's Avatar
We are being told to expect them around October
odpurple is offline
Old 07-19-2011, 07:09 PM
  #7964
thanks od
Old 07-20-2011, 01:56 AM
  #7965
heretic's Avatar
hello, could someone redirect me towards a picture of this EJ chassis I've read about ? i've searched this thread and googled it but can't find any. Thanks !
heretic is offline
