New Yokomo TC, the BD-5 >
Old 03-15-2011, 07:41 AM
  #2776
Trader Rating: 23 (100%+)
Originally Posted by kschu
use the big bumper cover for BD5...
Already using it...still breaking c-hubs.
pcar951 is offline
Old 03-15-2011, 07:56 AM
  #2777
kschu's Avatar
Trader Rating: 16 (100%+)
wow..
in my 2 years using bd5,bd5e,bd5w,bd5wr i only broke the c-hub twice...hitting the divider(wood) edge...
urs 9 times is very special case....u can try using the aluminium c-hub and knuckle...
kschu is offline
Old 03-15-2011, 10:31 AM
  #2778
I think I know where you're coming from. With the cold weather the graphite tends to be über brittle & plastic too sometimes. Had the same case myself & nothing help till they put the heater on.
Guess your only option is to 'give' a little & need not be greedy in the corners.
Sleepstream is offline
Old 03-15-2011, 10:50 AM
  #2779
Thanks all for your help and suggestions!
For sure the BD5WR is worth the effort, the car works so well, now that I have the setup nailed down. I WILL get the c-hub mystery solved!
thanks again
pcar951 is offline
Old 03-15-2011, 09:33 PM
  #2780
I had the same problem before so I end up using xray C-hub and steering block which I also converted to xray ECS to eliminate the chatter. The car width is the same.
here's some pics
ddd2k is offline
Old 03-15-2011, 10:17 PM
  #2781
kschu's Avatar
here's some pics
ur outer arm pin still remain the same ?
kschu is offline
Old 03-15-2011, 10:48 PM
  #2782
no you have to use the xray pin as well to hold the C-hub they're 3mm in diameter...and the xray c-hub has grab screws underneath to hold it. you will also have to shave .3mm from the c-hub to fit perfectly to the arm.
ddd2k is offline
  #2783
+1 ?? did you drill the arms or sleeve the pins? Looks great!
pcar951 is offline
Old 03-15-2011, 11:43 PM
  #2784
I drilled it to have a better play...I think the yokomo pins are 2mm only, also the xray ECS uses C plastic blades for the outdrives, I run mod with the yokomo so the steel outdrives doesn't last long. The spool is by TOP and the outdrives is by someone that makes it here in the US which I found it on this forum also. This car has a lot of corner speed and I like so much than my Xray T3 2011 in terms of handling.
ddd2k is offline
Old 03-15-2011, 11:51 PM
  #2785
kschu's Avatar
yokomo steel outdrive cup wear out quite fast....maybe u can try roche spool spring steel cup...
kschu is offline
Old 03-16-2011, 10:30 AM
  #2786
CanyonCarverR1's Avatar
Any tips for removing some of the slop in the steering rack? I see the new WX kit has updated steering rack. Does anyone have the part numbers for the parts in it?
CanyonCarverR1 is offline
Old 03-16-2011, 10:46 AM
  #2787
defcone's Avatar
Trader Rating: 15 (100%+)
I think it's just the 8mm one, you could try putting new ball cups or layer some shrink wrap ontop of the ball before popping the ballcup on.
defcone is offline
Old 03-16-2011, 11:20 AM
  #2788
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
here's some pics
Man those look like sidepieces with a TOP spool .. am I right?
hanulec is offline
Old 03-16-2011, 11:28 AM
  #2789
According to RedRC it comes with the "8mm centre link and refined steering bel cranks".
http://www.redrc.net/?s=bd5wx
Old 03-16-2011, 11:53 AM
  #2790
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
The bearing holes fit tighter on the updated part. It will also help you get rid of those "chicken strips" They are in CA, you'll get the part in two days or so.
http://www.driftspeed.com/index.php?...oducts_id=1699
RAL is offline
