Like Tree80Likes
Tamiya F201
Old 05-13-2002, 04:17 PM
  #241
Regional Moderator
Darkseid's Avatar
Osherman: I didn't know I needed to glue the diff rings. I thought it was odd that the rings weren't keyed at all, but I didn't think about gluing them. I just tightened them and reassembled the suspension. I will see how it runs with my old ParadoxPro before I bother with the diffs again.
zombies: your making me jealous man. Adjustable motor mount, universals.....sounds too good to resist. Is there a website where I can check out these hop ups?
Darkseid is offline
Old 05-13-2002, 04:28 PM
  #242
rc-zombies's Avatar
Darkseid: Option parts from Tech-Racing can be seen at:
http://www.tech-racing.co.jp/op_parts_new.htm
You can order them from RainbowTen from Japan. I've ordered stuff from them several times. they very safe and reliable. Shipping is around 10-15 to the US via Priority mail. RainbowTen website: http://www.rainbowten.co.jp/english/index.html
if you do an item search for: F201 all the option parts will show what is in stock.
Also Square R/C is coming out with teflon shock pistons and stainless shock shafts. see: http://www.rc-square.com/
Still trying to find where I can get those...
for another F1 rc site check out: http://www.formula1-rc.com/
rc-zombies is offline
Old 05-13-2002, 04:37 PM
  #243
OSherman's Avatar
Darkseid--> It doesn't say in the manual, that i remember, about glueing, but this is just a little trick from past experience in sedan racing...Should apply not only to sedans, but any ball diff in general with non-keyed, diff-rings. I didn't glue my rings either, but since you mention that after all the tightening your's still slips that woould be my first step to finding the actual problem...
Either that or that TAMIYA diff-lube just works too darn good
OSherman is offline
Old 05-13-2002, 07:21 PM
  #244
dtm
dtm's Avatar
Originally posted by psycho
dtm
If you haven't gotten your diffs sorted out by now, try putting loctite on both the screw that holds the diff together and also the grub screw that is supposed to keep the main scew from backing out. I put a good sized drop on loctite on the tip of the grubscrew and my diffs haven't backed out, although other guys at the track on Sat did have problems.
Thks Psycho...I'll bear that in mind when I build the diffs!
dtm is offline
Old 05-13-2002, 07:44 PM
  #245
Manticore's Avatar
tks dtm, I am collecting feedback while you are asking !!
Manticore is offline
Old 05-13-2002, 10:10 PM
  #246
TPhalen's Avatar
Want to order some of those parts but....YEN???? How do we convert THAT??? Anyone know what our dollar is worth over there right now?
TPhalen is offline
Old 05-14-2002, 02:41 AM
  #247
dtm
dtm's Avatar
don't thank me....Thank Psycho!!!!!!
dtm is offline
Old 05-14-2002, 02:50 AM
  #248
David Galdo's Avatar
Trader Rating: 15 (100%+)
Here ya go TP: http://www.xe.com/ucc/
David Galdo is offline
Old 05-14-2002, 08:51 AM
  #249
Regional Moderator
Darkseid's Avatar
Osherman: its something I never had to do. The diff rings were always either keyed or had some other method to hold them in place.
The next time I take the car apart, I'll snatch the diffs out and glue them up.
rc-zombies: thanks for the links.
Darkseid is offline
Old 05-14-2002, 09:07 AM
  #250
psycho's Avatar
No way! Moon bought a toy electric car? I'm shocked!
psycho is offline
Old 05-14-2002, 09:18 AM
  #251
Regional Moderator
Darkseid's Avatar
I guess RainbowTen is out of stock on most of the best items. The universals or motor mount didn't pop up on the list.
Maybe by the time I'm ready to get some, they'll have them.
Darkseid is offline
Old 05-14-2002, 09:29 AM
  #252
rc-zombies's Avatar
F201 option parts sell out very quickly at Rainbowten. If you email them... they might be able to reserve the parts you want when they arrive. Because of the time difference best time to do a search is around midnight pacific time. that's when I found out the motor mount was available and the following night is was all sold out. I was lucky to get one. Good luck.
Old 05-14-2002, 09:39 AM
  #253
dtm
dtm's Avatar
Just built the diffs and have made a few obeservations. Maybe everyone knows already but I will repeat them here!!
1. Oil film on diff rings, outdrivers, screws, balls etc...clean everything with cleaner first!
2. Thrust bearing springs need to be seated (I remember this from the TC3 or MR4...) Fully compress springs 3-4 times.....both mine shorten in length by almost 1mm!!! and then stopped (of course!! )
3. I prefer thread lock on the diff plates/outdrivers compared to glue.....a little less permenant...but either will do!
4. Don't forget the grease on the head end of the screw (I did at first) it does make a slight difference!
5. Good tip from Psycho on using threadlock for both screws in the diff!
Just my 2 cents!
I still can't get the diffs as smooth as those on my Xray.......but they will do!!
dtm is offline
Old 05-14-2002, 09:41 AM
  #254
dtm
dtm's Avatar
He bought one...but he didn't say he was going to run it!!!!
dtm is offline
Old 05-14-2002, 09:55 AM
  #255
Manticore's Avatar
why you are shocked????? i have lots of toy cars including the GPs !!
