Tamiya F201
#271
Originally posted by Darkseid
I guess RainbowTen is out of stock on most of the best items. The universals or motor mount didn't pop up on the list.
Maybe by the time I'm ready to get some, they'll have them.
TECH Racing,,1200yen,FP2002 F201 TURN BACKLE TIE-ROD SET
TECH Racing,,700yen,FP2003 F201 TURN BACKLE BUSHROD SET
TECH Racing,,1200yen,FP2004 F201 TURN BACKLE REAR TORQUE ROD
TECH Racing,,350yen,FP2005 F201 TURN BACKLE ADJUSTING WRENCH
TECH Racing,,350yen,FP2009 F201 TURN BACKLE SERVO ROD
TECH Racing,,1200yen,FP2008 F201 DERLIN SUSPENSION BALL
TECH Racing,,3200yen,FP2001 F201 ALMINIUM MOTOR MOUNT
TECH Racing,,2300yen,FP2010 F201 DERLIN DIFF HOUSING
TECH Racing,,1680yen,FP2011 F201 SCREW SET BLACK
TECH Racing,,1680yen,FP2012 F201 SCREW SET CHROME
TECH Racing,,2200yen,FP2013 F201 UNIVERSAL SHAFT FRONT
TECH Racing,,2200yen,FP2014 F201 UNIVERSAL SHAFT REAR
TECH Racing,,680yen,FP2016 F201 DERLIN SUSPENSION BALL SET
#272
Beware- KY9 who invested a load of money in the Tech Racing stuff said that the ball ends that come with their turnbuckles are NOT compatable with the original Tamiya brass balls...you need to change those too!!
Wot...no front one way!!!
#273
the Tech turnbuckles come with different ball-ends for the ones that need it. Some of the turnbuckles utilize the same ballends and connectors
#274
For the Turnbuckles, Lunsford is much better
#275
Originally posted by KY9fat
Yer specially the motor mount!! need to do alot of cutting the chassis and the second deck!! Still I can't get it to fit yet
#277
I modified the stock motor mount and cut a rectangle in the chassis for the motor to freely adjust for a 27 tooth pinion. Motor does not break the plain of the chassis so it won't have road rash.
Did anyone else get two sets of some parts in your kit? I had two sets of the beveled gears, spur, and motor mount.
#281
Originally posted by TPhalen
So, the aftermarket parts FOR the F201 don't fit??? Nice. I'll wait for someone to make working aftermarket parts.
#282
Rumour has it (from Manticore!) that a local (Hong Kong) company 3 Racing will start making options for the F201. Judging by what they have come out with so far for the V1R, the quality should be pretty reasonable but the price will be significantly cheaper!!!!!
You may be able to get hold of 3 Racing stuff from Control Centre!
#283
#284
Originally posted by Manticore
Dont spread my Rumour !!
#285
Regional Moderator
My question is where are all these dang companies that are making hop-ups for minis and micros? I want some of those companies to realize the potential of the F201 and start pumping out hop-ups that fit and are availible here in the U.S.
Not that ordering from over seas is all that hard.
