Tekin RS/RS PRO on 1s Lipo Q&A
#376
Was installing a booster today (dimension engineering) and was checking the power supplied using my watt meter. Interesting thing, almost no current supplied to the RX. It is almost like the booster is just supplying the voltage so the speed control will turn on, not really providing the power for the RX circuit. Anyone else actually measured the current provided by the RX pack or booster?
John
John
Skiddins
#377
John
#378
hi guys getting into 12th scale and want to run lipo and use the tekin rs but i dont know what i have to do. Do i have to run a reciever pack and booster and does anyone have pics of a 1 cell lipo in their 12th scale
#379
You need either a booster or RX pack, but not both. The tekin wont work without it. If you are using version 200, you can turn on the speed control switch to activate the voltage cut off or you can leave it off. If you leave the switch off the voltage cutoff is not active.
John
John
#380
#381
Thanks the car is alot better than the driver I can assure you . I have cleaned up the wiring since that pic, the purple wire I bought from OD.
#384
So I pulled out my DB12RR to get it ready for the next race and decided to clean up the wiring. I shortened the servo and speedo wire to the receiver. While doing this I noticed that the deans plug could be soldered right on to the solder post on the Tekin RS.
#386
My spektrum rec's have four slots, steering, power, batt, and aux. I plug the booster/rec pak in the batt slot and the transponder in the aux slot. Does your rec only have three?
#388
You can get a Y connector to hook up the power and transponder in one plug. should be $3 to $5 at any local shop that carries stuff for planes.
John
John
#389
Nice Fantom Gear!!!! Hope it's performing well for you!!
#390
