Like Tree3Likes
Tamiya TRF415
Old 06-25-2006, 10:41 AM
  #14536
TryHard's Avatar
Originally Posted by Szimon
I found only the rear stabilizers which are sold as hopup - not front :-(
Send an email to the guys at RC Champ, they should be able to order the bars as a special order items for you
And on the roll bar front, I prefer to run them with softer springs, didn't suffer at halifax did I fab?
HiH
Ed
TryHard is offline
Old 06-25-2006, 01:12 PM
  #14537
kewdawg's Avatar
Yeah, the rears are listed in numerous place, but the fronts are nowhere to be found. Hopefully, Tryhard's suggestion will have a fruitful return.
kewdawg is offline
Old 06-25-2006, 04:05 PM
  #14538
Burlap's Avatar
I kept the front and rear bars off my old 415 for the MSX. Sure they are a different shape on the MSX, but I'll find a way to fit them if I ever need to run front bars.
Burlap is offline
Old 06-25-2006, 04:49 PM
  #14539
JRRobiso's Avatar
I thought you could use the TA05 swaybar set coz that's what I bought for my MSX just to get the front swaybars since I already have the rear swaybar set from my std 415.
JRRobiso is offline
Old 06-25-2006, 05:26 PM
  #14540
JRRobiso's Avatar
Short Reversible Susp Arm # 53928
Has anybody used the new Short Rev Susp Arm set (OP#53928) on their MSX yet? Is it good for carpet only or also good for asphalt tracks?
Tamiya USA said that if you use it & depending on what susp blocks you have, you may need to change the length of the swingshaft.
Any input would be nice. Thanks.
JRRobiso is offline
Old 06-25-2006, 05:38 PM
  #14541
Guo Chean's Avatar
does anyone try to modified the EVO 5 steering and bridge into 415 already? can show a picture how to modified thanks.
Guo Chean is offline
Old 06-25-2006, 06:49 PM
  #14542
mike ivy's Avatar
Trader Rating: 51 (100%+)
Question? would a Hot Bodies 39t pully work with a Tamiya 415 MSX Diff if so what would be the final drive ratio?
mike ivy is offline
Old 06-25-2006, 07:53 PM
  #14543
veecee's Avatar
Trader Rating: 34 (100%+)
9808028 Front stabilizer set. This is from a RC Champ pricelist.
veecee is offline
Old 06-25-2006, 08:45 PM
  #14544
Burlap's Avatar
I doubt if it will be an easy conversion, as you'll need a different base and top plate.
Burlap is offline
Old 06-25-2006, 11:31 PM
  #14545
Szimon's Avatar
thanks to all :-) I'll try to order it
Szimon is offline
Old 06-26-2006, 04:07 PM
  #14546
AWK
AWK's Avatar
I just got a 415MSX from someone in the forum here, and I was wondering if there was anything I should make sure I order in terms of spares or hopups?
AWK is offline
Old 06-26-2006, 06:29 PM
  #14547
AWK
AWK's Avatar
Also, what part on the car is the spool? Like I said, I just bought this car off a guy and need to make sure it will be legal for TCS.
AWK is offline
Old 06-27-2006, 01:12 AM
  #14548
Usually when we are talking about spool,we're refering to a solid axle for the front end. Instead of the front one-way,we replace it with a solid axle spool. This is a tuning aid, usually used on small twisty tracks....
The box stock 415MSX doesn't comes with a spool.
Ben.C is offline
Old 06-27-2006, 03:30 AM
  #14549
Szimon's Avatar
Unfortunately I heard that Tamiya discontinued producing their spool. CarKing have to buy the other one, for ex. Titanium racing.
Szimon is offline
Old 06-27-2006, 03:35 AM
  #14550
Szimon's Avatar
Default 2mm (thinner) lower desk
I'm preparing for winter/carpet season (I'm not stupid for winter ) and I cannot find thinner (maybe 2mm?) lower desk than 2,5 mm which is in the box.
Do tamiya produce that one?
Szimon is offline
