Tamiya TRF415
Just finished putting on the conversion a couple days ago. Nice!
I made a tool box out on the MS box.
Looking good! Mine should be arriving on Monday and I'll be building it straight away methinks. Then I should get a chance to run it on Wednesday night. I'm just going to use the LWT suspension first up and then use the DJ Pro Module suspension after that to see the difference.
Did you guys see these? Need to buy, haha.
Can anyone point me in the right direction on how to gear the reg 415 for a stock motor?? What should my finial drive be. I am running a p2k and a monster
gears
26/27/28 100spur monster not sure on the p2k
Ok cool i'll start there.
race
Originally Posted by Nexus
Are you just saying you bought the LW suspension and want to mount it on your stock 415?
If so it should fit fine. I have gone back and forth with LW and stock suspension on both the 2.5 and 3mm chassis. Only difference when going from chassis to chassis is the number of shims on the inner hingepins and the length of the hingepins.
Monster I run 37T (5-minute runs)
P2K Pro I run 36-37T (5-minute runs)
19t I run 38T (5-minute runs)
23T I run 38T (here in Thailand I race with the HPI/Orion 23T SL motors and most of us run them 5.6-5.8 ratios. (8-minute runs)
MSX Conversion on Std 415
Well I don't know why Tamiya says the MSX Conversion has to be mounted on a TRF415 with LW Suspension Kit?
My conversion has mounted fine on the Standard 415 with Standard suspension no problem. Also to note, you can mount the # 49344 heat sink beam in between the rear bulkheads and it looks cool compared to the standard brace in there.
190mph...I also coundn't understand why it could be mounted with the LW suspension? Wierd. Mine fit really well with the original arms. I kinda like the older arm set. After taking pix withe the LW sus. I put the old sets back.
Originally Posted by AKARA
If you use the stock 102T spur, with stock 27T motors, you should start out running 6-6.3 ratio. I run a 37T pinion. Maybe you can start from there.
Originally Posted by odawg315
i think it greatly depends on your track as well as your motor, i run a 7.8 ratio on my local very tight twisty track
Of couse it does. Just somewhere for the guy to start off of.
I don't have my car in front of me right now but I think I have it set @ 33/104 with a final drive of 6.9 & after a 5 min race, the motor isn't extremely hot to touch. I did notice that I could still go one tooth higher to give a final drive of 6.7 to give more straight line top speed but might lose a little torque in the infield. But this is just my set-up based on the track I race on.
Just be careful though **drew85** not to fry your motor while your finding the right gear combo for your car. Hope my "2 cents" help you out.
